Phaser Q?
im planning on doing a cam swap on my L9H but im not too familiar with the phaser. i plan on keeping the vvt , im going with the gpi vvt ss3 cam. what will i have to do since im keeping the vvt will it be just swapping cam,springs and pushrods, or will i need to do something with the phaser.
Will more than likely need a limiter for it, talk to gpi when you buy the cam they usually have them in stock! I think mine was 55 or 59 through them when i ordered my cam!
That is a loaded question... The answer really depends on whether the engine has dod hardware on it or not..... If it doesnt then yes so long as the cam looks ok when you pull it you should be fine, however there is a chance that you will have a bad lifter/cam lobe, so just check the cam really well when you pull it! If everything looks good and you have all "normal" non dod lifters you will be just like a gen 3 swap!!
09CamdSilvy
Mar 2, 2016 09:47 AM
Ryan23silverado
Oct 29, 2002 06:01 PM
