cam swap woes!!!
Old Apr 13, 2016 | 06:22 PM
70inbville's Avatar
Default cam swap woes!!!
Alright all,
swapped a howards asa cam into my sons 2003 5.3, tsp mail order tune (x3 now) won't idle UNTIL you unplug the vacuum line to the brake booster??? it will idle runs not well and his mpg is around 3.5 mpg! For the life I can't figure this out. TSP has no clue, any thoughts. new maf, o2 sensors in since swap. I am out of ideas. thanks
Old Apr 13, 2016 | 06:31 PM
1FastBrick's Avatar
Custm2500's Rude Friend
That means it's dumping fuel.
Take it to someone who can tune it in person.
Old Apr 13, 2016 | 06:37 PM
70inbville's Avatar
That's what I told him to do. My idea for tsp mail order to get it close, but NO cigar yet. I am in over my head with tuning and pcm controlled trucks (for now) thanks for the reply!
Old Apr 13, 2016 | 06:49 PM
1FastBrick's Avatar
If all you did was a cam swap it should run on a base tune. Just don't beat on it.
Old Apr 13, 2016 | 10:16 PM
Wolftrk99's Avatar
could be a problem with the idle air settings in the tune, I would imagine an idle relearn needs to be done, especially after I am assuming send the pcm out, I have seen bad iac motors cause a similar issue where vehicle wouldn't idle until a vacuum leak was created to allow for more air to be pulled in
Old Apr 15, 2016 | 09:35 AM
2002_Z28_Six_Speed's Avatar
Does the car run better if you unplug the MAF? Was the MAF used or look broken?
Did you change injectors at the same time?
Old Apr 16, 2016 | 12:06 AM
X_Racing1's Avatar
in for the conclusion.
Old Apr 16, 2016 | 07:55 AM
70inbville's Avatar
We swapped the throttle body and boom, now it idles! now to send the pcm back to tsp because the first tune they did was probably right. thanks for the help all!! He did have a random code awhile back for the tps I think, but none since? stay tuned for a final answer after another tune.
Old Apr 16, 2016 | 07:40 PM
X_Racing1's Avatar
I've read where people drill a small hole in the throttle blade to help it idle.
Old Apr 16, 2016 | 08:24 PM
Wolftrk99's Avatar
Sounds like the culprit was a bad iac or possibly tps, considering its an 03 i am going to assume it was a dbw tb.... Which essentially means 2 iacs..
