Phaser Q?
Old Aug 21, 2016 | 09:04 PM
silvy13's Avatar
Default Phaser Q?
im planning on doing a cam swap on my L9H but im not too familiar with the phaser. i plan on keeping the vvt , im going with the gpi vvt ss3 cam. what will i have to do since im keeping the vvt will it be just swapping cam,springs and pushrods, or will i need to do something with the phaser.
Old Aug 22, 2016 | 01:21 AM
Wolftrk99's Avatar
Will more than likely need a limiter for it, talk to gpi when you buy the cam they usually have them in stock! I think mine was 55 or 59 through them when i ordered my cam!
Old Aug 22, 2016 | 12:07 PM
silvy13's Avatar
Thanks for the heads up ...do you happen to know if i will need to pull off the heads and change out lifters ..or will it be like doing a cam swap on a gen lll besides the phaser?
Old Aug 22, 2016 | 07:04 PM
Wolftrk99's Avatar
That is a loaded question... The answer really depends on whether the engine has dod hardware on it or not..... If it doesnt then yes so long as the cam looks ok when you pull it you should be fine, however there is a chance that you will have a bad lifter/cam lobe, so just check the cam really well when you pull it! If everything looks good and you have all "normal" non dod lifters you will be just like a gen 3 swap!!
Old Aug 23, 2016 | 09:05 AM
silvy13's Avatar
From what i was told at the dealership 6.2 only come with vvt and the 5.3 come with dod/vvt. Thats why im not too sure whether to pull the heads off or not truck only has 28,000 miles on it
Old Aug 23, 2016 | 10:26 AM
Wolftrk99's Avatar
If the valley cover is flat its non dod, with that many miles, you should be fine to just swap it like a gen 3..... Again just check the cam lobes for damage!
Old Aug 23, 2016 | 10:27 AM
Wolftrk99's Avatar
Non dod valley cover
70inbville
Apr 17, 2016 05:04 PM
Wolftrk99
Mar 29, 2016 02:30 PM
09CamdSilvy
Mar 2, 2016 09:47 AM
kazfan30
Feb 22, 2016 01:42 PM
Ryan23silverado
Oct 29, 2002 06:01 PM
