2008 yukon build.....Err uh mod thread
Old Jul 14, 2016 | 10:59 PM
  #271
1FastBrick's Avatar
Custm2500's Rude Friend
I'm still not sure how people deal with that on a daily basis...
Old Jul 14, 2016 | 11:03 PM
  #272
Push through, and dream of winter... Sad part is hunidity affects cold same as heat.... At home it will be 35 with 50-60% humidity, and be quite chilly, ill drive to my mothers house where it will be 20 with 10% humidity abd it feels warner at her house....
Old Jul 14, 2016 | 11:19 PM
  #273
1FastBrick's Avatar
Well that sucks...
Old Jul 15, 2016 | 07:16 PM
  #274
Finished 6l80 internals up this evening, got the turbine shaft seals installed and sized, and reinstalled the 1-2-3-4/3-5-R drum and torqued the converter housing/pump assembly down and installed the tailshaft housing....
Tailshaft bolted on
Ready for valve body....
Torque converter housing torqued and cnverter seal installed....
Old Jul 15, 2016 | 07:18 PM
  #275
Got my l92 today as well.... Still waiting on pistons, rings and bearings!!
Freshly machined l92 block......
Heads and crank....
Old Jul 15, 2016 | 09:25 PM
  #276
1FastBrick's Avatar
You got the block back and no pistons??? How did they check to see if the wall to piston clearance was correct?
Old Jul 15, 2016 | 10:08 PM
  #277
They forgot to bring them, they have em, just left em at the shop, along with my bearings and rings, and the crank sprocket.... I an going to measure everything anyway, before it goes together...
Old Jul 17, 2016 | 12:51 AM
  #278
Ordered a shifter cable bracket and shift lever for the 6l80 today, going to pick up the filter monday.... Sadly i will have a lot less in this trans swap than i do in the 4l60 i built for my 99, including the cooler lines, shift lever, etc... the turbine shaft seals and vb separator plate set me back less than $20.... Not sure i have hit $800 in this yet!! Still better than buying one!!!
Old Jul 20, 2016 | 07:04 PM
  #279
Got valve body back together, pan on and filter in.... Some dummy forgot to take any pics, what i get for rushing..... also half *** bolted the brackets on today.... All $7 worth of shift lever and cable bracket.... Now to get engine together, and get ahold of a set of trans cooler lines, tcase input shaft, a trans cooler, torque converter and a somewhat long weekend to get it all in and go through tcase and front differential(since im going to drop it for clearance anyway)! At some point i will probably upgrade the g80 in the rear end, but for now at least im going to cross my fingers, toes and anything else that it doesnt break....figure i should be alright with 3.73s that are in it at least for a while..... Need a break from big projects for a while... Rather spend time driving and tuning them than replacing parts at this point.... And start saving for bigger better things!!!
Old Jul 21, 2016 | 07:16 PM
  #280
Added up all the receipts for the trans today... $987 before converter, cooler lines , shifter cable and tcase input shaft.... Figure i will probably have something around $13-1400 in the trans when its all said and done....
