03 Wants More Power
#32
Originally Posted by niugnep
Looking forward to updates. Maybe once you drop the other tranny out could compare them size wise, or any other info for the swap (same style driveshaft spline or does it have the bolt on 3 bolt flange I keep seeing in pics?)...stuff like that...
#33
Originally Posted by Wide Open
From my initial measurements the transmission is the same overall length and does have a splined output shaft. The mount on the transfer case also appears to the be same distance from the bellhousing. Not sure of the tunnel clearance yet.
#34
Need help. Do ECM's need to be married to the BCM?
I tried cranking over the engine today but nothing happened when I turned the key. The fuel pump didn't even cycle.
I took the ECM out and plugged it into a NNBS '07 and it did the same thing. Only the engine light came on when I tried to crank the engine over.
Any ideas?
Any ideas?
#38
Originally Posted by ZZebes
hate to rain on a parade, but, isn't the NNBS Can Bus and the NBS OBDII
Do tuning programs let you mess with BCM items too???
#39
As it turns out the 6L80 does not have an external TCU or a VSS connection.
I have a couple of companies researching custom harness possibilies.
#40
Not much of a parade so far...
As always, typing things out is a PITA, makes it kinda hard to explain and understand...
