Z06 calipers on 15"rotors on a SSS
Old 11-20-2008, 07:28 PM
  #21
03ssilverado's Avatar
Location: On a one way dead end street... And I can't get out
If you look around you can save some money. I know the kit can be bought with everything for around 3000K I have been doing some searching and I have found some really good deals. I am saving up for the upgraded 15's and I am selling the rears brand new in the box $300 Just need to finish payment on the front calipers, need the front brackets, lines and to put them on..
Old 11-21-2008, 02:17 PM
  #22
jf-03-ss's Avatar
Originally Posted by Stampede4ever
Can you give a price break down?
Thanks.
F & R Zo6 Calipers=around $1,000.00
F & R Brake Pad=$175.00-$350.00 (depends what you get)
14" rotors=about $150.00ea.
Front 15" rotors=$300.00ea.
5 piece SS brake lines=about $175.00
Bango bolts and crush washers (get at dealer)
Good brake fluid=around $10.00/qt.
Brackets to mount calipers=$250.00
Old 11-22-2008, 07:56 AM
  #23
Banned
TexasPainter's Avatar
Originally Posted by jf-03-ss
There was alot of unused brake pad w/ the 14's so I was somewhat disappointed, esp. w/ how much money I spent on the entire set-up. The 15's use the entire brake pad and it now stops like I thought it was going to.
How is your truck coming along?
make sure you tell everyone how much material you have to grind off of the calipers though...
Old 11-22-2008, 08:52 AM
  #24
jf-03-ss's Avatar
There is some work involved to get the brackets JYD made to work properly.
Is that what you wanted to know TexasPainter? (JYD)
Old 11-22-2008, 04:01 PM
  #25
2001CamaroGuy's Avatar
Where did the rotors come from (I noticed someone mentioned Baer) and what size rims do you have?
Old 11-22-2008, 11:11 PM
  #26
Banned
i are not JYD. but i have noticed in some of the other threads about these that some serious grinding has to be done to the calipers to make them fit. dunno if i really want to hack up my pretty new calipers.
Old 11-23-2008, 02:42 PM
  #27
jf-03-ss's Avatar
Removed!
Old 11-24-2008, 07:10 PM
  #28
Banned
honestly, for the money, id rather give up a little pad contact. im not auto-xing or roadracing my truck.
Old 11-24-2008, 08:35 PM
  #29
hmmm...well how about using the caliper with the CORRECT SIZE rotor and DESIGNING the bracket to place the caliper in the CORRECT location...... just a thought
Old 11-24-2008, 09:08 PM
  #30
1Bear's Avatar
Well, it is a good thought. However, allot of the problem is actual rotor availability. When the brackets were initially designed, they were built around a fairly easily obtainable rotor. Take a good look at the pic’s with the 14" Powerslot's. The caliper is brought down as far as it could go without hitting the center hub. If a rotor could be found with a smaller dia. hub/hat, then the caliper brackets could be tweaked a little more, bringing the caliper in. Then slightly smaller wheels could even be used. I also went from the 14 incher's to the 15's and can honestly say, I wouldn't have it any other way now.
Quick Reply: Z06 calipers on 15"rotors on a SSS
