Z06 calipers on 15"rotors on a SSS
Old Nov 20, 2008 | 07:28 PM
  #21
03ssilverado's Avatar
From: On a one way dead end street... And I can't get out
If you look around you can save some money. I know the kit can be bought with everything for around 3000K I have been doing some searching and I have found some really good deals. I am saving up for the upgraded 15's and I am selling the rears brand new in the box $300 Just need to finish payment on the front calipers, need the front brackets, lines and to put them on..
Old Nov 21, 2008 | 02:17 PM
  #22
jf-03-ss's Avatar
Originally Posted by Stampede4ever
Can you give a price break down?
Thanks.
F & R Zo6 Calipers=around $1,000.00
F & R Brake Pad=$175.00-$350.00 (depends what you get)
14" rotors=about $150.00ea.
Front 15" rotors=$300.00ea.
5 piece SS brake lines=about $175.00
Bango bolts and crush washers (get at dealer)
Good brake fluid=around $10.00/qt.
Brackets to mount calipers=$250.00
Old Nov 22, 2008 | 07:56 AM
  #23
TexasPainter's Avatar
Banned
Originally Posted by jf-03-ss
There was alot of unused brake pad w/ the 14's so I was somewhat disappointed, esp. w/ how much money I spent on the entire set-up. The 15's use the entire brake pad and it now stops like I thought it was going to.
How is your truck coming along?
make sure you tell everyone how much material you have to grind off of the calipers though...
Old Nov 22, 2008 | 08:52 AM
  #24
jf-03-ss's Avatar
There is some work involved to get the brackets JYD made to work properly.
Is that what you wanted to know TexasPainter? (JYD)
Old Nov 22, 2008 | 04:01 PM
  #25
2001CamaroGuy's Avatar
Where did the rotors come from (I noticed someone mentioned Baer) and what size rims do you have?
Old Nov 22, 2008 | 11:11 PM
  #26
Banned
i are not JYD. but i have noticed in some of the other threads about these that some serious grinding has to be done to the calipers to make them fit. dunno if i really want to hack up my pretty new calipers.
Old Nov 23, 2008 | 02:42 PM
  #27
jf-03-ss's Avatar
Removed!
Old Nov 24, 2008 | 07:10 PM
  #28
Banned
honestly, for the money, id rather give up a little pad contact. im not auto-xing or roadracing my truck.
Old Nov 24, 2008 | 08:35 PM
  #29
hmmm...well how about using the caliper with the CORRECT SIZE rotor and DESIGNING the bracket to place the caliper in the CORRECT location...... just a thought
Old Nov 24, 2008 | 09:08 PM
  #30
1Bear's Avatar
Well, it is a good thought. However, allot of the problem is actual rotor availability. When the brackets were initially designed, they were built around a fairly easily obtainable rotor. Take a good look at the pic’s with the 14" Powerslot's. The caliper is brought down as far as it could go without hitting the center hub. If a rotor could be found with a smaller dia. hub/hat, then the caliper brackets could be tweaked a little more, bringing the caliper in. Then slightly smaller wheels could even be used. I also went from the 14 incher's to the 15's and can honestly say, I wouldn't have it any other way now.
