Wiring for mirror options
Old Sep 7, 2004 | 09:31 PM
moregrip's Avatar
what a rush!
Originally Posted by snakeoiler
I would think that you would not have a problem with this. It seems to me that the only difference would be that the motor, in the mirror, is made to move the mirror unit in a different (in and out vs. folding in) direction. Everything else remains the same. Plug and play.
hmmm.....
Old Sep 7, 2004 | 11:09 PM
tranzfourmd's Avatar
If I recall correctly the mirrors on the 03 escalade moved in and out, were powered, had the puddle lamp and were heated??? maybe you could look into those?
Old Oct 2, 2004 | 01:03 AM
SnakeOiler's Avatar
My puddle lamps are now operable. I installed a relay and triggered the coil through the courtesy lamp circuit, instead of through the BCM (which is the factory way).
What was really cool is that I did not splice one wire. I used some metri-pak 280 connectors to plug into open circuits in the relay box and fuse box.
[edit] oh yeah. . . I used an SPST relay (bosch 332 019 150 or 332 019 151) that has two 87 pins on it. So each one of those goes to a puddle lamp.
Old Jan 21, 2012 | 12:34 AM
robotchickenFrank's Avatar
Registered User
Hi I was wondering if any body knows how to wire for power mirrors. I bought some and now I would like to make them work with a switch. thanks
FlyingLow
Nov 24, 2015 10:05 AM
carid
Oct 28, 2015 08:24 AM
muncie21
Sep 7, 2015 09:55 PM
InsaneDomestics
Sep 7, 2015 09:19 PM
01 5.3
Sep 2, 2015 02:17 PM
