Wheel question
Old Jan 2, 2007 | 06:31 PM
badelf's Avatar
Default Wheel question
i found thìs wheel and it is 20" x 9.5" and has a +5 offset.i don't know the backspace of it and i would like to know if i have to worry about the clearance on the inside.in germany you don't get information about the backspace.it is 6 x 5.5 but it is suppost to get on a nissan truck.
it's a 2004 sierra 2wd and it is stock height.
what do you think or are there any other things to pay attention to ?
Old Jan 2, 2007 | 06:44 PM
TWANKYDEUCE's Avatar
they wont rub on the inside any, but they will probably stick out some. Are you sure those are truck wheels and not for cars? They look like they ahve a fwd offset
Old Jan 2, 2007 | 06:48 PM
nightrunner's Avatar
Mr. Obvious
make sure they are hub centric and not lug centric
toyota has a 6 on 5.5 but are lug centric for gm trucks
not sur eon the nissan wheels though
Old Jan 2, 2007 | 07:03 PM
badelf's Avatar
hm
i don't know if they are hub or lug centric.
they sell the +5 offset for the nissan patrol.
www.smcwheels.de the homepage is also in english.
6 lug wheels are not common over here.
Old Jan 3, 2007 | 09:54 AM
badelf's Avatar
the center bore is 110 mm.what size is the gm hub ?
if it is to big do i have to get some centric rings ?
Old Jan 19, 2007 | 01:07 PM
the gm hub is around 78mm, you will have to get hubcentric rings. when you do, dont get the metal ones, get the rubber ones
5.3Caprice
Nov 7, 2015 08:56 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
