What Back Spacing
Old Jun 8, 2004 | 06:27 PM
ts99's Avatar
Default What Back Spacing
I have a 99 GMC Sierra and am thinking of purchasing Eagle 219 wheels. The truck is stock height and I may drop it 2" in the rear to level it.
I probably will get the 20" X 9.5" wheels with Toyo Proxy 295X45X20 tires.
I have a choice of 5.0, 5.5, or 6.0 back spacing as well as +8mm or +21mm offset. I want the wheels to be flush with the outside of the fenders. Which combination is correct?
Thanks
Old Jun 8, 2004 | 06:35 PM
6 that should be perfect
Old Jun 8, 2004 | 06:42 PM
ts99's Avatar
What about the offset?
Old Jun 8, 2004 | 07:00 PM
Alwhite00's Avatar
Thanks
I have 18 X 8 Eagle 219's and they have 5" BS and they sit pretty much flush with the outside of the truck. 255/55/18's By the way it's a 2/4 drop.
LK
Old Jun 8, 2004 | 07:13 PM
backspacing and offset is the same thing. you want about 3inchs of face on a wheel tuck. so a 20x9.5 id go with 6 inch backspacing. the only problem with eagle is that you cant get custom offsets. but you shgould be fine with 6inch
Old Jun 8, 2004 | 07:15 PM
Scream's Avatar
MOOBIES Moderator
I have 20X8.5's with a 6" b.s. Will a wider wheel with the same offset still work? Wouldn't it put the back of the tire closer to the frame/wheelwell?
Old Jun 8, 2004 | 07:18 PM
i had 5 3/4 on my 20 X8.5 budniks, he really needs 6.5. i wouldnt go lower then 6
Old Jun 10, 2004 | 11:05 AM
creederado's Avatar
My old Moda's, were 20x9.5 with a 6". Perfect if you want a beefy look.
Old Jun 10, 2004 | 01:26 PM
IntroWheels's Avatar
No......backspace is from the back of the wheel (frameside) to the backpad of the wheel. If you went to a 20x10 with 6" BS, it would give u another inch and a half on the street side of the wheel, and probably stick out.
GXPJAY
Feb 13, 2022 08:15 AM
axekick
Sep 7, 2015 07:01 PM
omc8
Aug 10, 2015 10:39 PM
