Tires rubbing
Old Apr 26, 2005 | 10:47 AM
wes00silverado's Avatar
Default Tires rubbing
Right now I'm running 275/60/17s on my stock height 2000 silverado RCSB. I was looking at lowering it and different things and I did some measuring in my fender well and with the wheels cut it looks like i can only lower it like an inch in the front without them rubbing. I haven't measured my rims but I think they are the 7.5" wide ones. Any input on what I could do? I wanna get 18s and do like a 2/4.
Old Apr 26, 2005 | 11:38 AM
OKLAGMCRUISER's Avatar
you can do a 2/4 with 255/55/18's without rubbing issues, but any lower and you will likely have a problem.
Old Apr 26, 2005 | 11:58 AM
if this helps....im running 285/50/20 on a 20x8.5 rim with a 2/4 djm drop and they only rub on the inner plastic fender well(theres a part that sticks out father than any where else) at FULL turn.but as for normal driving their perfect.
Old Apr 26, 2005 | 12:40 PM
TWANKYDEUCE's Avatar
you could runa 2/4 with the tires you have now...I had a 2/4 with 31.6" tall tires.
yours are exactly 30" tall
Old Apr 26, 2005 | 01:21 PM
Deckhand's Avatar
I have 275/60/17s with a 2/4.. works good.
Old Apr 26, 2005 | 01:52 PM
TXsilverado's Avatar
what rims do you have? do you know the backspacing?
Old Apr 26, 2005 | 06:28 PM
Deckhand's Avatar
Weld EVO 17x8, 5" BS
Old Apr 27, 2005 | 03:26 PM
Thanks for the info. I'll prolly just go with you guys cause you know a lot more than I do about this stuff.
gaps
Oct 15, 2015 02:53 PM
bisqikss
Sep 8, 2015 03:35 AM
screaminian47
Sep 7, 2015 08:20 PM
the owl
Sep 4, 2015 04:09 PM
hackrst
Sep 2, 2015 05:27 PM
