tire pressure question
Old Apr 28, 2006 | 02:04 PM
Holty's Avatar
Notorious BIG
Default tire pressure question
you guys running 22inch wheels....what do you set your tire pressure at? I have 305/40-22 Pirelli Scorpions and am looking to get the most mileage out of them possible. thanks.
Old Apr 28, 2006 | 04:10 PM
getchusum99's Avatar
i dont have 22's but i do know a lil about tires. i would go to pirelli's website and check first, if not its always a good plan make sure that all of your tire is on the ground at the same time, so you wont overinflate and run out the middle of the tread, also dont under inflate em so you wont run out the outside treads. but id say around 35lbs for all around good wear. maybee some other guys will reply
Old Apr 28, 2006 | 04:17 PM
Allgonoshow's Avatar
Good luck, I got 10,000 miles on a set I had, hard to get the air pressure right.
I ended up at 30 psi front and rear, too much pressure they drove like bowling *****, steered all over the place
great sticky tire and look good, but don't expect em to last much IMHO
I honestly think we are better of buying the cheapest tire we can get in big stickies because no matter what you get they don't last.
I've had Goodyears, yoko's, Pirellis and now Hancooks. Some say Toyos last but I can't confirm that and they are pricey.
dave
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
GMCtrk
Jul 17, 2015 06:39 PM
