Thinking about adding a cowl hood, opinions?
Old May 15, 2010 | 02:59 PM
Mud slinger's Avatar
Originally Posted by DV2000NJ
Look at a stock '06.
The 06 and HD hoods are the same?
Originally Posted by charcold-bowtie
Hd hood is more of an OBS thing. If you go to the 06 hood, you have to change the grille as well.
Yeah I thought about the 06 swap too. It would be a nice update/upgrade to the truck, but im not sure its what I really want.
Originally Posted by TIM Z
Heres my old 04 Z with a goodmark cowl hood.
Every chevy should have a cowl , they are just too sexy!!
Heres an HD hood for ya
I agree, that is sexy. I like a wider cowl though.
Originally Posted by 05RST2NV
I think the cowl hoods even look better on the lifted trucks. Makes the truck look bigger and more aggresive. But get a steel goodmark, I just ordered one. The fiberglass hoods will warp.
Thats the look im going for. Ive heard that a lot, ill get a steel one for sure.
Old May 15, 2010 | 03:12 PM
budhayes3's Avatar
PT's Slowest Truck
Not exactly, the 06 hood sticks out a little further and won't fit properly with a 03-05 grille, the 06-07 hood and grille have to be swapped together or the hood won't line up with the grille properly.
Old May 15, 2010 | 03:25 PM
DV2000NJ's Avatar
13 Second Truck Club
Well, there's also no "HD hood" for the '03-'05 trucks, the HDs had the same hood as the half ton.
Old May 15, 2010 | 03:29 PM
Yeah I knew you have to swap the grille and everything from and 06+ truck.
Ok because I have seen an HD swap on an 01-02 half ton before, and you can tell it's not an 06 hood. At least they look different.
Old May 15, 2010 | 03:41 PM
TIM Z's Avatar
11 sec. Truck Mod
almost.
The 05 2500 HD had a HD hood. Then 06 -07 half tons and 2500's all had that hood.
The 01-02 2500 HD's had their own style HD hood. Which is one of my fav's.
it can be bolted on a 99-02 truck and 99-06 tahoe , suburban and looks killer.
To post above, you cant get a wider cowl hood. Not sure what your talking about.
Old May 15, 2010 | 03:43 PM
DV2000NJ's Avatar
almost.
Good call, I was just about to go back and edit that into my post.
Old May 15, 2010 | 03:46 PM
TIM Z's Avatar
11 sec. Truck Mod
I wasnt pickin on ya bro, just adding some info LOL
You are correct that the 03 and 04 2500 and half ton both shared the same hood.
Old May 16, 2010 | 05:52 PM
almost.
Yes you can :nunchuk1:
Old May 16, 2010 | 06:56 PM
TIM Z's Avatar
11 sec. Truck Mod
Ok who makes that one then... Youve found it so buy it already!
Old May 17, 2010 | 06:11 PM
Because im trying to save up for a 4l65e. If I find a used cheap one I will, until then im working on go fast goodies.
