Switch Panel Question
Old May 3, 2004 | 01:08 PM
Mr Powell's Avatar
8 Second Club
Default Switch Panel Question
I want to put my ***** for my Subs, and my Remote Harness for my radar where the 4x4 Buttons would be on a 4WD Truck. Its a 04 so it has that little cubby hole there. What exactly should I use to replace it and what is the easiest way to go about doing so???
Old May 3, 2004 | 01:24 PM
MacADaYear's Avatar
I have an 00 but if its like mine you just take the dash bezel off and the cubby hole spot will pop right out
Old May 3, 2004 | 01:42 PM
Mr Powell's Avatar
8 Second Club
Looked like it should, but what should I use to make the actual panel for the switchs, its the dark charcoal interior.
Old May 3, 2004 | 04:09 PM
1TRUESS's Avatar
Are you talking about something like this? I can email you some pics if you like!
Old May 3, 2004 | 04:10 PM
MacADaYear's Avatar
Where did you get the material 1TrueSS?
Old May 3, 2004 | 04:16 PM
1TRUESS's Avatar
I will get some pix together and maybe a write-up.
Old May 3, 2004 | 04:32 PM
1TRUESS's Avatar
I bought the corner dash pieces on Ebay. The pieces are what covers up the fuses. I cut it to fit behind the bezel. They are the same color and texture as all the other pieces in the truck so it looks factory.
The corner pieces I got off ebay and the insert that need to come out.
Back of the bezel.
Bezel off with the wires hanging out of the dash. I used weather pack quick connects so I could take the dash off without redoing the wires.
Panel fused to the bezel using JB Weld.
Another pic of the Panel fused to the bezel.
BTW: The two holes are for my LED blue security lights and the switch is to manually turn on my LS1 fans.
713truck
Aug 18, 2015 09:32 PM
97aztecgt
Aug 13, 2015 02:11 PM
USMCvet0311
Aug 1, 2015 07:45 AM
