Smooth painted handles
Old Jun 8, 2005 | 11:19 AM
Default Smooth painted handles
I've searched and searched, but I can not find the part number. I'm hoping someone could help me out? I'm looking for the Black painted smooth door handles with out the lock, that will fit an 03 1500. All my searches came up with the numbers for the ones with the locks.
Thanks, any help is appreciated.
Old Jun 8, 2005 | 02:51 PM
Fogle07's Avatar
If You Dont Want A Lock On The Driver Side Then Your Going To Have To Use A Rear Handle. I Got Mine From My Dads Body Shop But I Used Escalade Handles. I Used The Pass. Side Front And The Driver Rear For My Truck. You Can Call Up A Chevy Dealer And They Will Give You The Part Number
Old Jun 8, 2005 | 03:20 PM
04BlackSilverado's Avatar
I used a rear handle from an escalade on my passenger side too, You just have to swap the stock lever on the inside of the handle with the escalade one. The escalade handle for the rear is too long to fit in the door. It is very easy to do. The escy handle has a brass pin and may need to cut it( I used vice grips and carefullp pulled it out), but the stock handle has a plastic pin that comes right out. Before you remove anything from the stock handle member exactally how it's built, I had to figure it out because i forgot.
Good Luck
Old Jun 8, 2005 | 05:05 PM
endo's Avatar
Why don't you want the lock holes?
And offtopic, 04BlackSilverado, did you run that 14.9 before or after the tune & e-fans? And was it with those heavy steel wheels?
Old Jun 8, 2005 | 10:35 PM
JSmith's Avatar
Have you tried our part number thread in General Truck Topics?
https://ls1tech.com/forums/showthread.php?t=114619
Old Jun 8, 2005 | 10:47 PM
After fans and tune and yes steel wheels, With full street weight and a bunch of crap in the bed. Goin this friday and WILL get into the 14.8 range, maybe if the planets align I'll see 14.7. I'll try it with no spare and maybe loose the bumper if I end up giving enough of a **** that day.
Old Jun 9, 2005 | 04:35 PM
Does anyone know the parts number for painted door handles for dark blue metallic with the chrome handle like the escalade? i cant seem to find it anywhere. any help would be greatly appreciated.
Old Jun 9, 2005 | 09:16 PM
The truck had been broken into by punching the lock into the door, then lifting the lock rod. I figured if it did not have locks, then they can't be pushed in.
Yes, I have. All I could find was the Escalade numbers and the smooth painted with the lock for the drivers side.
Old Jun 9, 2005 | 10:04 PM
SS Crew's Avatar
Hey, look what I found:
Part numbers for pre-painted Escalade door handles
You can get your handles already painted from GM on the web. They arent to expensive either. You can even get a painted tailgate handle and bezel.
Here are a few handle #'s. Make sure you check them out before ordering to verify they are correct and the #'s haven't changed as they sometimes do.
GM part numbers...
Escalade door handles (painted bezel with chrome handle):
Black 41U (WA8555):
15745149 FLH
15745148 FRH
15745141 RLH
15745140 RRH
Pewter 11U (WA382E):
15745145 FLH
15745144 FRH
15745136 RLH
15745137 RRH
Arrival Blue 91U (WA815K):
15093424 FLH
15093425 FRH
15093426 RLH
15093427 RRH
Carmine Red/Red Fire 72U (WA526F):
15745151 FLH
15745150 FRH
Summit White 50U (WA8624):
15066575 FLH
15066574 FRH
15066577 RLH
15066576 RRH
Pearl White 98U (WA800J):
15074056 FLH
15074057 FRH
15074058 RLH
15074059 RRH
Silverado/Sierra/Tahoe/Yukon Suburban (All painted door handles):
Victory Red 74U (WA9260) (no chrome):
15015969 FLH
15015970 FRH
15015983 RLH
15013234 RRH
Carmine Red/Red Fire 72U (WA526F) (no chrome):
15041755 FLH
15041756 FRH
15029900 RRH
15029899 RLH
Dark Spiral Gray 62U (wa805k) (no chrome):
15093821FLH
15093820FRH
15093807RLH
15093806RRH
Arrival Blue 91U (wa815k) (no chrome):
15093823 FLH
15093822 FRH
Black 41U (WA8555) (no chrome):
15150735 FLH
15150736 FRH
Indigo Blue 39U (WA9792) (no chrome):
15015961 FLH
15015962 FRH
15015975 RLH
15015976 RRH
Sunburst Orange Metallic 56C (no chrome):
15195271 FLH
15195272 FRH
15195273 RLH
15195274 RRH
Storm Gray 14U (WA391E) (no chrome):
15015959 FLH
15015960 FRH
Summit White 50U (WA8624) (no chrome):
15015963 FLH
15015964 FRH
15015977 RLH
15015978 RRH
15013231 Rear cargo door handle
Copper 69U (WA381E) (no chrome):
15015967 FLH
15015968 FRH
Med Green 47U (WA9539) (no chrome):
15053113 FLH
15053114 FRH
Sunset Orange 71U (WA633H) (no chrome):
15053115 FLH
15053116 FRH
Pewter 11U (WA382E) (no chrome):
15015957 FLH
15015958 FRH
Silverado/Sierra/C3/SS Tailgate handles/bezels (All painted handles):
Victory Red Tailgate Handle 74U (WA9260) (no chrome):
15187999 tailgate bezel
15188002 tailgate handle
Pewter Tailgate Handle 11U (WA382E) (no chrome):
15755401 Handle
15752896 Bezel
Black Tailgate Handle 41U (WA8555) (no chrome):
15188001 Handle
15187998 Bezel
Arrival Blue Tailgate Handle 91U (WA815K) (no chrome):
15188003 Handle
15188000 Bezel
Silver Tailgate Handle (no chrome):
15196652 Handle
15195043 Bezel
Green Tailgate Handle (no chrome):
15755402 Handle
15752897 Bezel
Black Escalade handles:
15745149 FLH
15745148 FRH
Black tailgate handle 15188001
Black tailgate bezel 15187998
ALL BLACK:
Front LH 15150735
Front RH 15150736
I hope that helps everyone.
SS
Old Jun 10, 2005 | 02:59 AM
azchevydude's Avatar
If you are looking for the escalade ones try below : http://cgi.ebay.com/ebaymotors/ws/eB...category=33642
