Shouldn't have any more traction problems.
Old Oct 12, 2009 | 05:42 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default Shouldn't have any more traction problems.
I was hooking OK on street tires but with running nitrous next time and the cold temps at the end of the year I figured it was time to step up and make sure I have plenty of traction!
I got them at the very end of the day at work and only had time to mount them. I will balance them tomorrow and get them on the truck! Then time to play for a minute and wait till the 21st when I go the track again!
Old Oct 12, 2009 | 05:45 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Sweet!! I want 4
Old Oct 12, 2009 | 05:46 PM
charcold-bowtie's Avatar
what size and how much did you pay? if you dont mind...
Old Oct 12, 2009 | 05:48 PM
custm2500's Avatar
Ph.D. in HUBRIS
28x11.5x16 I paid $185 each plus tax. I work for a tire shop so I mounted them and got free tubes.
Old Oct 12, 2009 | 05:52 PM
cool thanks
Old Oct 12, 2009 | 06:16 PM
colekill's Avatar
KickinAssAndTakinNames
tubes!? didnt know you had to run tubes
Old Oct 12, 2009 | 06:26 PM
custm2500's Avatar
Ph.D. in HUBRIS
They are bias so yes you have to run tubes. I was debating on going bias or radial and after asking over on ls1 and calling Mickey Thompson I decided to go bias. They offer more traction expecialy for a truck since it becomes an issue easier than in a car. The tires are signifigantly lighter but with a tube they weigh about the same as the radial fo the same size.
Old Oct 12, 2009 | 07:04 PM
8ALTNG's Avatar
nice. be carefull running bias on the rear and radials on the front. The truck will like to skate around a little on the top end of the track when you mix the two
Old Oct 12, 2009 | 07:08 PM
custm2500's Avatar
Ph.D. in HUBRIS
Yea I am looking to find some bias for the front but I am not worried about it really. In all actuality the bias will cause the truck to "walk" around and the radials will roll straight like they always have.
Old Oct 12, 2009 | 07:58 PM
nonnieselman's Avatar
Im running Hoosier Bias and i didnt use any tubes. they hold air just fine, and yea on the top end it gets a lil fun
