shaking
Old Feb 15, 2008 | 02:03 PM
00Silv4.8's Avatar
as for the clips causing a vibration I would really like to know how after the wheel is already torqued on and all they're just gonna crush right up to the rotor. But either way, the tire shop shoulda taken them off anyway unless they're a bunch of toolbags
Old Feb 15, 2008 | 03:32 PM
budhayes3's Avatar
PT's Slowest Truck
If the clips are still on there, some aftermarket wheels wont sit flush against the rotor and a pulsation could occur. You would still get them to their torque spec, but they wouldn't be flush.
Most common problem that causes a brake pulsation are rotors that have too much runout (warped), as mentioned above. Other items that may cause a brake pulsation are bad wheel bearings or severely worn steering components, but there should be other symptoms (noises, looseness in the steering) if that was the case
Old Feb 15, 2008 | 03:43 PM
xlcooplx's Avatar
Are the wheels stock wheels or aftermarket? It could depend whether they are hub centric or lug centric. If they're lug centric, they will tend to wobble at higher speeds. You can get hub-centric rings for the wheels to correct this.
Old Feb 15, 2008 | 04:22 PM
00Silv4.8's Avatar
read the 1st post... "...tires and rims...". Lug centric is absolutely a possibility.. too bad its not a speed vib its a slowing down vib... thanks for playing.
Old Feb 19, 2008 | 07:37 PM
TWOFOURS's Avatar
Default shaking
ultra 17x8 thunder#247/248 w/pirelli str,s ultra wants these rims back .thank you everybody for your help i live in shallotte n.c. its hard to deal with someone over the phone in cali.
BCraven1018
37
Dec 20, 2016 11:46 AM
dantheman1540
Nov 1, 2015 02:59 AM
Pimpinpete
Sep 8, 2015 07:39 PM
black00chev
Aug 28, 2015 03:39 AM
bgray
Jul 23, 2015 10:56 AM
