shackles
Old Oct 31, 2003 | 11:05 AM
FLASH's Avatar
Default shackles
whats up guys i have never done any suspension work on my truck and about two weeks ago i put some shackles on my truck. but now on any little bump the truck squeaks at the rear. even when i got off the truck i can hear it and i only weigh 160 pounds. what do you all think it might be?
Old Oct 31, 2003 | 11:35 AM
rgvsierra's Avatar
i have that noise to, really annoying, i also have a squeak when i brake, not rotor/pad squeak, but another type, sort of like is something is dry or stretching out, dont know, very hard to describe.
Old Oct 31, 2003 | 11:47 AM
GREGGO's Avatar
Did you guys get the ones with grease zerks? If not spray some belt dressing on them and work them a little.
Old Oct 31, 2003 | 11:50 AM
FILE's Avatar
From what I hear, that noise is due overtorquing the bolts and not sufficioet lubricant. I would loosen up the bolts and retorque them not as tight as the first time. What brand do you have btw?
FLASH's Avatar
i'll try that thanks
Old Oct 31, 2003 | 12:40 PM
When installing rear shackles - need to install them loose - then put the truck back on the ground - then tighten the shackle bolts - lube the bolt and the sides of the bushings - should solve the problem....
Old Oct 31, 2003 | 02:27 PM
OUT2WIN's Avatar
I had that problem too due to overtightening the bolts!
FlyingLow
Nov 24, 2015 10:05 AM
dhorner77
Sep 11, 2015 05:10 PM
LPCWS6
Sep 1, 2015 10:03 PM
Darknight-4
Sep 1, 2015 05:50 PM
signguy62
Jul 27, 2015 03:42 PM
