droppin' a 2500...and other stuff
Old Oct 28, 2003 | 09:13 PM
Yelo's Avatar
Default droppin' a 2500...and other stuff
NOBODY makes any parts except an axle flip kit to drop this thing so........
how much of a drop in the rear will I see if I pull the overload leaf (bottom leaf)??, how much if I pull the overload AND the next leaf up??
the front isn't an issue because with the stock t-bars backed out most of the way I can just about stuff the front wheels and I don't want to go that far....just 2-3" front and back
does anyone know if the Hotchkis sway bars will work on the 14 bolt axle??....if it is just bracket problems I can fab brackets
TIA
Al
Old Oct 28, 2003 | 10:29 PM
Hit Man X's Avatar
TIA
Al
You should try pulling the lift blocks if you have them also. I found me a set of 2x4 U-bolts for my 4x4 so I can drop the assend 2".
Hotchkis stuff won't work but I know what will...
Old Oct 28, 2003 | 10:32 PM
Hit Man X's Avatar
http://www.hellwigproducts.com/antis...tic4x4_gm.html
Old Oct 28, 2003 | 10:34 PM
Yelo's Avatar
I don't have lift blocks....the rear-end spring perches sit right on the springs, the picture in my sig has a watercolor filter applied but you can see how high it sits!!
and don't keep me in suspense Hit Man....WHAT sway-bars will work with the bigger axles??
Old Oct 28, 2003 | 10:38 PM
Yelo's Avatar
oh..yeah...sorry
I was a little late on the post
Old Oct 28, 2003 | 10:57 PM
Hit Man X's Avatar
How wide are the HD springs like on your truck?
Mine looks silly with the assend up like that too...I did order a T-Bar Key set and never got them and canceled the order. So I am just going to drop the rear.
LOL...the suspense is bad eh? Hellwig came highly recommended to me via a Ford truck site (hope that's okay with you!) also Addco apparently makes bars too
Old Oct 28, 2003 | 11:11 PM
Yelo's Avatar
springs are 2.5" wide.....can I maybe use 1/2 ton drop shackles or are the 1/2 ton springs only 2" wide??
the suspense was absolutly killing me
Ford is OK by me....as long as I'm not driving it
Old Oct 28, 2003 | 11:24 PM
Hit Man X's Avatar
My springs are 2.5" wide too...and I drive a 1/2 ton. Maybe they are larger on the 2500HD/3500. But as luck will have it, you can prolly use the 1/2 drop parts.
If you get those sways post up how ya like them. I am pretty sure I am going to order a set for the ol' Blue Oval and prolly the Z. Won't happen until early next year tho'.
Hey... Ford is better than Mopar!
Old Oct 29, 2003 | 11:02 PM
Keith's Avatar
My dad had a 3500 1998 crew cab fleetside that we dropped in the back with shackles. Worked real well. Leveled it out and all. Shackles might be the answer.
Old Oct 31, 2003 | 03:13 PM
Yelo's Avatar
well, it looks like the 1500 4" shackle and hanger drop from DJM will work on the back ($190), it seems the '99/'00 2500 non-HD has the same frame/suspension as the 1500 with the only difference being the number of leaves in the rear spring-pack and the 3/4 ton torsion bars in the front
by pulling the overload leaf in the back in combo with the hanger/shackle drop I should see about 5" rear and I can crank the torsion bars in the front down far enough to still give it a rake (I want it level front to rear though so I won't go THAT far down in the front)
with a 3/5 drop I will STILL have almost 4" of rear suspension travel and almost 3" in the front !!!....I never realized just how HIGH up this thing really sits !!
$A_Money$81
Mar 27, 2023 10:25 AM
cheyenne383
Nov 13, 2015 09:24 AM
drummer0415
11
Oct 24, 2015 08:16 PM
lxcoupe
Sep 25, 2015 12:36 PM
maxspeed05V
Sep 23, 2015 10:48 AM
