roll pan
Old Aug 27, 2003 | 10:49 PM
03red5.3's Avatar
Default roll pan
thinking of putting a roll pan with the hide away hich but i would fill in the body line so it looks smooth but wouldnt that have to be done with bondo what would you all do if i can find a bumper cover to fix over the fatory i might keep that in mind
Old Aug 27, 2003 | 11:32 PM
JSmith's Avatar
Default Re: roll pan
Sir Michaels roll pan.
Old Aug 28, 2003 | 03:50 PM
if you don't have a sportside, buy a metal pan and you can just fill the seam in with a welding machine
if you do have a sportside, but a fiberglass pan and you can fill the seam in with a little more work.
either way the smooth look will definately be nice
Old Aug 28, 2003 | 10:52 PM
JSmith's Avatar
I plan on re-working my truck's rear end and getting a new steel roll pan. I'll be welding it in and having the box resprayed. I'm also probably going back to a normal tailgate with the license plate getting moved onto the new roll pan. Not sure if I'll flip the handle on the new gate or not.
Old Aug 29, 2003 | 07:32 AM
Ling_650vette's Avatar
yeah, i was going to say, it would depend upon which material you chose to use for the rollpan, as to whether you'd need to use bondo or not to fill.
Old Aug 30, 2003 | 01:44 AM
definately get a steel pan and have it welded in, you will be happy with the outcome, shaving the tailgate handle will make you even happier that you did it
Old Aug 30, 2003 | 06:11 AM
That's what I don't like about mine, with the steel pan and plastic bed, it don't go together that well. I spent hours adjusting it, to get it just right, but then you got them lines! Yours look really good!
Old Aug 30, 2003 | 07:12 AM
CHAGO's Avatar
I dont really care too much for a rollpan on a stepside, just dont like the way it drops off. Looks clean on a fleetside. I'm thinking about just painting the rubber around the chrome pewter to match the truck.
Old Aug 30, 2003 | 09:58 AM
JSmith's Avatar
I've got my handle shaved but I'm not sure if I'll do it again though.
SloSVO
Nov 22, 2020 07:34 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
lxcoupe
Sep 25, 2015 12:36 PM
