Replacing AC control panel
Old Jul 25, 2004 | 11:02 AM
SaintLos's Avatar
Default Replacing AC control panel
Hey guys, I'm new on the board. AC control panel in my 2001 silverado starting having LED's go out. Found a complete identical replacement via ebay. Is this a straight unplug old/plug in new or is there more to it(i.e. unplug battery, do rain dance, etc.)?
thanx
Old Jul 25, 2004 | 12:37 PM
chevymec's Avatar
Its a direct replacement. I looked it up as to how gm says to replace it and it says after replacing the module to remove the HVAC fuse for 60 seconds to allow enough time to clear old calibration values. Ive never done this but now that ive seen, I might start!!
Old Jul 25, 2004 | 12:39 PM
chevymec's Avatar
Oh yeah , it says to leave the IGN off while the fuse is pulled. Then to turn the IGN to on.
Old Jul 25, 2004 | 12:59 PM
Onyx 02's Avatar
I have the same problem in my 02. The left LED lights burned out, so I have only the right LEDs working. It's annoying but, I don't want to pay a bill to fix the problem. Everything else works fine.
Old Jul 25, 2004 | 06:07 PM
SaintLos's Avatar
Rock on, I'll let you guys know how it turned out on Tuesday when I get a day off to do the deed.
Next on agenda....AEM Brute Force intake
Old Jul 26, 2004 | 09:02 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Now you're talking! Good choice on intake!
Old Jul 26, 2004 | 10:11 PM
SaintLos's Avatar
The AEM is ordered and should be shipped this week....should be next week's mini project on my day off.
Old Jul 27, 2004 | 01:55 PM
SaintLos's Avatar
UGH, the AC panel I bought from an ebay salvage yard had all the bottom buttons' white LED's out (orange ones still worked). Guess I will use the ebay'd panel for the experiment in changing the LED's individually. These lites suddenly feel alot less important.
Old Jul 27, 2004 | 04:37 PM
Scream's Avatar
MOOBIES Moderator
I've had the same light problems, and my dimmer switch SUCKS! If you find a way to change the lights out, let us know!!!
Old Jul 27, 2004 | 05:17 PM
chevymec's Avatar
I noticed this morning that my a/c wouldnt cut off even by unplugging the low pressure s/w. When I replaced my ac control ( leds burnt out) it was in the winter so I never noticed the a/c. I pulled the HVAC fuse for 60 seconds , and wha-la it cut on and off with the button!! guess I will definatly start doing this every time I replace one.
nickpc82
Nov 2, 2015 02:49 PM
smokeshow
Aug 23, 2015 08:23 PM
thewrx
Aug 12, 2015 08:28 PM
