Removing white wax film from black ABS plastic
Old Jan 15, 2010 | 10:10 PM
02'Z71ONDUBZ''s Avatar
Default Removing white wax film from black ABS plastic
Well I hit my door handles with the buffer a few times the last time I waxed the truck, and the white film left behind is starting to look pretty bad. Any suggestions on cleaners to remove the film? Thanks
Old Jan 16, 2010 | 05:40 AM
j225's Avatar
for a temp fix peanut butter works well,but you'll have to do it once a month probably
Old Jan 16, 2010 | 09:54 AM
TXsilverado's Avatar
time for color matched door handles.
Old Jan 16, 2010 | 10:24 AM
cttandy's Avatar
I have found it is usually best to use something alcohol based to wash the parts. I have even used straight isophropyl ?spelling? alcohol (like you clean wounds with). After you clean it, use a good black plastic restore struff, should sell it at the local auto parts house.
Old Jan 16, 2010 | 01:18 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Look for a product called "Black Magic" at your local parts place.
Old Jan 16, 2010 | 02:14 PM
kylem's Avatar
Get one of the Absorber drying chamois or any chamois, i have the absorber and that one works for me. Get it wet and rub were the wax is. You will have to give it a little pressure when you rub it.
Kyle
Old Jan 16, 2010 | 02:36 PM
03rado5.3ls's Avatar
ive used a mr clean magic eraser to get wax off plasric before
Old Jan 16, 2010 | 07:22 PM
Blownme's Avatar
I have worked in the bodyshop business for 8 yrs there is a product called (Black Again) made by Wizard's. They make compounds and polish. It is made just for automotive plastics and will clean and restore your plastic in one step. A small bottle will go a long way. You can find it at your local paint distributor.
Old Jan 16, 2010 | 07:59 PM
BlackGMC's Avatar
Resident Retard
Murphry's oil soap. It is made for cleaning would but when used onplastic it does a great job. Just mix a little in a bucket of water
Old Jan 16, 2010 | 08:47 PM
DV2000NJ's Avatar
13 Second Truck Club
303 aerospace protectant. Works 10000x better than anything else I've tried.
http://www.303products.com/
