Quick question before I lower the truck?
Old Nov 30, 2003 | 01:04 PM
onyx's Avatar
14 Second Truck Club
thats with a 2/4 hotchkis drop though, isnt it?
Old Dec 1, 2003 | 08:58 PM
Y2KSierra's Avatar
onyx_silverado,
i'm not sure what the backspacing is on the newer SS wheels, i don't think they tuck though as they kinda sit flush with the fenders (at least on the few SS's i've seen in person)
to run a 275/45/20 tire on an 8.5" wheel you will need 6" of backspacing, on an 8" wheel you will need 5.5" of backspacing to run that tire.
My centerlines only have 5" backspacing on an 8" wide wheel so i had to run my 40 series tires to avoiding rubbing with the 4/6 drop.
Any clue on the specs of the SS wheels?
Old Dec 2, 2003 | 02:12 AM
Yes mine is 2/4 hotchkis, and I got 20x8.5x5.5 backspace on mine!
Old Dec 5, 2003 | 08:53 AM
onyx's Avatar
i took a look at the truck before i left for central asia, and there did seem like there was space for the body to sit that low and still turn...
what again is backspacing??...
Old Dec 6, 2003 | 10:06 PM
That is the offset of the rims from the center of the hub. It determines how a certain wide rim will fit in alignment with your truck. On a 8.5" rim like mine 5.5" backspace from the back of the rim to the face, makes the rim flush with the body, where 5", would be a little in from the body and so forth and so forth. If you run 9" rims, 6 inches of backspace would be flush, if you run 8" rims, 5 inches of backspace would be flush on Chevy and GMC trucks.
Old Dec 7, 2003 | 02:24 AM
onyx's Avatar
the wheels are 8.5" so that should be good right?.. also w/ the DJM kit, does it bottom out alot?
Old Dec 7, 2003 | 03:20 PM
onyx's Avatar
i really want to give my truck a low, aggresive and driveable appearance... i'm hoping this DJM setup does it for me...so any help would rock.. thanks!
Old Dec 10, 2003 | 12:18 AM
Be carefull with tire size on the DJM suspension. Nice as hell ride, but a lot more bounce in that suspension, that could cause some rubbing. My friends truck has DJM and he runs 285/65/16s on his, and he rubs all the time over big bumps. But then again when you drive normal their is no problems, and his truck rides so damn nice too.
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
92SS Wagon
14
Aug 4, 2015 06:42 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
