Pics of the AC Controls in Blue
Old Feb 19, 2006 | 06:10 PM
04BlackSilverado's Avatar
Default Pics of the AC Controls in Blue
Here's the pics
I found that this was easy and only took about 2-3 hours.
On the center part where it shows the red color I had to use two White LED's for the red to show red and not violet, as it would with only the Blue LED's.
The camera always makes it looks like there are dead spots but there isn't any. It is nice and pure blue.
Old Feb 19, 2006 | 06:14 PM
The blue part in the temp controls is split because that's where the ***** were blocking the light.
The circuit was already laid out nice in groups of 2 lamps. So it made it easy to place the LED's. All I needed to do was place a 220ohm resistor where the power came in. You can see it in the first pic(far right ribbon). Just make sure that you orient the anode and cathode right(+ and- ). You can see where I used a marker to mark some of the - spots.
Old Feb 19, 2006 | 06:24 PM
TravisH's Avatar
damn man that looks good!
I want to do that in mine, but with red leds
Old Feb 19, 2006 | 06:52 PM
Onyx 02's Avatar
Damn, that looks AWESOME!!! I want to do that, but don't have the patience. Is there someone here that still does this for a fee?
Old Feb 19, 2006 | 07:05 PM
I will soon enough...
magnetized's Avatar
Very cool
Old Feb 19, 2006 | 08:11 PM
Onyx 02's Avatar
Cool, LMK!
Old Feb 19, 2006 | 08:12 PM
agreif's Avatar
Hey, nice work on the AC, but I couldn't pick out where you put the resistors or where the actual led's were? Are the lights where all those little squares (6 + the 2 white LED's + 3 blue lights for the indicators)?
Old Feb 19, 2006 | 09:34 PM
There is only one resistor due to the LED's are laid out in series groups of two. With the LED's in series I only need one 220ohm resistor. Then all of the Series branches were in parallel.
The stock indicator orange LED's were not changed, I could have But I wanted to make sure I see them. And I may Lower the resistance or the 220ohm resistor due to a slight brightness difference between it and the radio. But other that that I am very happy with the outcome.
I changed the pic below to show where the parts are.
Old Feb 19, 2006 | 10:37 PM
SBChvy's Avatar
nice work man-that looks easier than the 99-02 havc. By the way where did you pick up the smds-i've been searching for the window controls for weeks with no results.
