paint/dye that matches 99-07 classic charcoal gray interior
Old 10-12-2017, 11:26 AM
  #21
TXsilverado's Avatar
while on the subject of dashes out of trucks, does anyone know how the passenger "handle" is held to the dash? the dash I bought has that handle removed, and I assume that i'll need to remove mine to get my dash out.
Old 10-12-2017, 11:29 AM
  #22
nevermind....I thought I knew just about everything there was to know about these older trucks. didn't know this!
Old 10-12-2017, 02:37 PM
  #23
ILuvJDM's Avatar
Glad you got it figured out, I had to do the same on my truck when I swapped dashes
Old 10-12-2017, 07:47 PM
  #24
smokinlmm's Avatar
Originally Posted by 97_ek
Was this done with the dash still in the truck? Mine is chipping away, and it needs to be touched up. If I can do it without removing the dash that would be great?
I did mine while it was still in the truck just make sure you tape off your windshield.
Old 10-13-2017, 12:20 AM
  #25
Custm2500's Rude Friend
1FastBrick's Avatar
The dash cover is easy to remove.
I pulled the cover, I used a real fine grit sand paper to help blend the edge of the peeling paint. Then I used a fine scotch brite pad and some dish soap with warm water to clean the surface and prep it for spraying.
You have to use real light coats or it will lift the edge of the original paint. You really have to be patient. I spotted the bad areas first to cover them, then gave the whole thing a few light even coats.
Old 10-13-2017, 12:28 AM
  #26
1FastBrick's Avatar
FYI you can stick a long flat blade screwdriver to release the tabs at the front of the windshield that hold the clips on the dash.
If the tabs break off, you can purchase a Plastic weld epoxy and re attach them. Double sided tape won't hold up in the long term.
Old 10-13-2017, 09:49 AM
  #27
I'm ordering the dye today. Not sure when i'll have time to do it, but i'll take pictures along the way.
Old 10-23-2017, 09:59 PM
  #28
distracted guy's Avatar
Post .....
Does this come in a brush application style or only spray?
Old 10-24-2017, 10:15 AM
  #29
take the paint code to a dealer and have it mixed however you want.
Old 08-19-2022, 05:14 PM
  #30
GrannySShifting's Avatar
IIRC 17163 is med drk pewter which is the lighter medium grey 992 or 92I
I have used that as well with similar results.
The pictures you posted what GM color code is that and what paint?
My truck looks to be that color, but on the option codes it has the 92i - which I thought you were saying was SEM 17163 to match not the 17223
What does GM call these things? Im really also trying to find out a paint that matches the dark gray almost black inserts that my light gray interior truck has because Im changing the headliner to something like that and want to paint the grab handles, dvd enclosure etc to match
Quick Reply: paint/dye that matches 99-07 classic charcoal gray interior
