Orange Peel?
Piss Pumps for Sale
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
1 Post
Orange Peel?
Anyone that has colour matched interior peices know how to get rid of the orange peal texture that shows up after you primed and did a first layer of paint? Do I have to sand it all back down to the plastic and do more sanding?
when I went to Chevy about that they told me to sand it pretty good, prime it get some finer sand paper prime it again and then get somethin like 1k grit and sand it one last time, prime it and paint it. That was for door handles, tail gate revrie and the fin on the top of the gate. I dont know exactly what ur trying to paint but it sounds like its a plastic piece ur working on so it should be the same process.
How bad is the orange peel? If it's too severe you may want to start over and sand down more of the texture in the plastic, then use filler primer to fill in the remaining texture. Sand the primer with 600 grit, spray some color, lightly wet sand between each coat, yada yada.
Piss Pumps for Sale
1 Post
ok I sanded it down to bare plastic and removed like 98% of the texture, Im going to use the same method as last time cause it turned out good besides a few little spots of orange peel so Ill retry everything again, thanks guys
Steve-O-08
04-19-2018 09:32 AM
