Not happy w/ KMC wheels, considering Centerline
I bought a set of KMC wheels a few weeks back. At first I liked them, but now I'm not so sure.
Here's a pic of the wheel: http://www.gotwheelsandtires.com/cat...seat-Black.jpg
They are 20x9.5 and running a 285/50/20 sumitomo tire.
My first problem is the backspacing, while they look nice and I love the black, they stick out about 1/2'' too far. This just looks funny to me from certain angles.
My other beef is that the wheel/tire combo weighs in at 86lbs a piece. This is on the heavy end of the scale for sure...i've heard a 20" Centerline with the same tire weighs under 60 lbs. Anybody with Centerlines confirm this?
I really want to do the hotckis 2/4, and with the way the wheels stick out of the fender wells, I don't think it will look right.
Any advice would be appreciated.
edit: snapped some quick pics to help out http://community.webshots.com/user/fubar123321
IMO, the truck doesn't look bad with them sticking out just a little, however I think it could look better. What are your future plans with the truck, lift, lower or stock?
My Centerlines with 265/50/20 weigh 63 lbs each.
If you are planning on dropping it in the future, you need to at least get smaller tires or else you are going to have crumpled fenders when you go over bumps.
Based on the tire size and backspacing, your wheel and tire combo looks like it would be better off on a Tahoe or 'Burban.
Thanks for the comments guys. My future plans are to drop it 2/4 with the Hotchkis kit.
Tdrumm, I think you have a great looking truck there. What is the backspacing on your Centerlines?
I think I will definitely be changing the wheel tire combo. With almost 90 lbs on all four corners, handling, acceleration, and braking are all pretty sluggish.
Thanks for the compliments. My wheels are 20X8 with 5" of back space. It puts the edge of the tire just about flush with the edge of the fender. They don't have enough backspacing to tuck with a 4/6 drop so I'd have to run a much shorter tire. I think a 255/45/20 will work.
This is not good being that i ordered these same rims but in a 22X10 with a 285/35 on all four corners. Looks like im going to run into the same problem. Guess ill find out either today or tomorrow. If thats the case back they go.
Mcduffys, hopefully you won't have the same problem as I did. But being 22x10 I bet you will. I guess this is what I get for being the first person with these rims. Just keep in mind that they will be very heavy. I wouldnt be surprised if 22s ran you close to 95 lbs or so, with tire.
