new look for blue... rims, tires, and 4/6 drop
Old Feb 21, 2010 | 08:32 PM
  #31
sixltrbtr's Avatar
Looks awsome. I might do the flip.
Old Feb 22, 2010 | 03:04 AM
  #32
Blown06's Avatar
8 Second Truck Club
I'll have to go look at the part number. I've already forgotten, lol.
I'll be anxious to see how your 29.5's fit. Cause mine didn't at all with the 6.5" backspace. I had about 1/16" of clearance between the leaf and still would have had to roll the fender.
Old Feb 22, 2010 | 08:59 AM
  #33
TXsilverado's Avatar
Originally Posted by bluecajun5.3
thanks again everyone!
what kind of problems you had with the kit or you don't like? yes the bars are sitting parallel to the ground. it dead hooked yesterday with the 75 shot coming on at 2800.
thanks Stew. i plan on getting that kit but i was talking about the part number for the shocks.
thank you. no, just lower ones.
thank you Carlos. i haven't measured it, just kept the 2.5* or 3* shims i already had on it.
just a poor design IMO. the notch is crap compared to others that i have seen, the bottom piece that lays on the spring is not flat at all, i bent the upper brackets with the bolts and dont think i put too much torque on them at all. im really just not wild aboutt he design and the weight. im guna weld on some new spring perches and drop 20 lbs and get the pinion angle i want and not worry about stuff moving.
Old Feb 22, 2010 | 10:55 AM
  #34
bluecajun5.3's Avatar
11 Second Truck Club
i know. i was following your build and seen you couldn't make them fit. i took some measurements and i figured it would work. i have exactly 1" clearance between the inner sidewall and the leafspring. i'm guessing the extra half inch in rim width with the same backspacing as you helped me.
i understand what you are saying now. i bent the upper bracket also. just had to realign it a while ago while putting back my street tires on. they had shifted and the pin was off on the hole.
Old Feb 22, 2010 | 12:26 PM
  #35
i know you just dropped some good money on it, but you might look into what im doing...its all welded, and factory style so you know it will never shift on you. just put it where it belongs and weld it up. it weighs ALOT less and doesnt include all of the unnecessary crap.
here is a better quality flip kit for 13$
http://www.summitracing.com/parts/SUM-720025/
  #36
Old Feb 22, 2010 | 12:37 PM
  #37
Bumpers's Avatar
yus looks good
Lamartian92
Sep 10, 2015 09:27 PM
Codog
Aug 16, 2015 08:23 PM
Porscharu914
Aug 10, 2015 10:57 PM
bgray
Jul 23, 2015 10:56 AM
