Need Quick Help
Old Jun 18, 2004 | 05:04 PM
Blown 96 WS-6's Avatar
Default Need Quick Help
I'm in the middle of installing my new front spindles and I haven't bought a service manual for the new truck yet and I need a few torque numbers:
top ball joint
bottom ball joint
hub
calipers
Thanks guys, I'll come back and check for a response in a bit.
Old Jun 18, 2004 | 06:45 PM
ACDenali's Avatar
Wish I knew man..........good luck!
Old Jun 19, 2004 | 02:50 AM
sleepersilverado's Avatar
should of posted in the lounge prob would of got more responses... unfortuinatly i am not were my manual is so i can not help.
Old Jun 19, 2004 | 09:43 AM
I guess I'm not familiar enough with this forum to know where the true wrenchers hang out. I would not have suspected the lounge
I called McGaughy's and they gave me the number to a shop that installs their stuff and they gave me some numbers but they didn't sound all that convincing. I used their numbers but I will verify them all as soon as I can get someone to check a service manual.
Upper Ball Joint - 75#
Lower Ball Joint - 45#
Hub - 110#
Calipers - 110#
I also checked with Helms and they don't even have th 04 available for sale yet. So, is anyone has a 99 and newer service manual and can check the numbers I would be grateful
I did get the front done and the rear shackles last night. I will do the hangers this morning and get some pics up later.
Old Jun 20, 2004 | 08:38 PM
pritch55's Avatar
Here is the info I was able to pull for a 2003 Silverado. This is for a 4WD.
Attached Thumbnails Need Quick Help-caliper-bracket-install.jpg   Need Quick Help-brake-caliper-replacement-install.jpg   Need Quick Help-upper-ball-joint-install.jpg   Need Quick Help-hub-4x4-install.jpg   Need Quick Help-lower-ball-joint-4x4-install.jpg
Old Jun 20, 2004 | 08:44 PM
pritch55's Avatar
Here are the specs for a 4WD, only the lower ball joint and hub are different between them.
Attached Thumbnails Need Quick Help-lower-ball-joint-4x4-install.jpg   Need Quick Help-hub-4x4-install.jpg
Old Jun 20, 2004 | 09:11 PM
Thanks for digging that up for me. It helps and I appreciate it.
Old Jun 21, 2004 | 02:09 AM
it is not that it is that more people view the lounge than this forum. and normaly for some info like that you will get more replies in there.
o and lets see some pics
Edit: just saw your other post with pics.
Old Jun 22, 2004 | 06:17 PM
pritch55's Avatar
When you said you had torsion bars I also assumed that your truck was 4WD. Here are the specs for a 2WD truck.
Attached Thumbnails Need Quick Help-hub-2wd-install.jpg   Need Quick Help-lower-ball-joint-2wd-install.jpg
Old Jun 22, 2004 | 06:25 PM
Thanks for digging those up for me. I actually took it to my alignment/suspension shop for an alignment today and I had them double check all the torque values and adjust the torsion bars. It looks perfect right now, nice and level. I'll get some new pics up later this week but I'm very pleased overall.
drummer0415
11
Oct 24, 2015 08:16 PM
Wrecker 426
Oct 7, 2015 12:11 PM
01silvy
Sep 26, 2015 10:20 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
