need pics of trucks with 2"/4" drop
Old Sep 9, 2004 | 06:57 PM
TwoFast's Avatar
Default need pics of trucks with 2"/4" drop
Hy guys I want to see pics of your truck with 2"/4" drop on stock tires and rims. Do these ride good, does it make the truck more stable around corners and such?
EDIT: How will a 2" front drop coil and a 4" rear drop shackle and drop spring hanger combination ride? Would it be better to get a lowering spindle or does it not rally matter?
Old Sep 9, 2004 | 07:10 PM
Alwhite00's Avatar
Default Here's mine...
00 GMC With a 2/4 drop. I don't have any pics with the stock wheels but I will run them in the winter. It seems to lean a little bit less in the corners but that is not the reason I lowered mine. I ended up putting a ART C-Notch in the rear because even with 1" pancake bumpstops it still only had like 1 1/4" clearance, Now it rides awesome. (I also have rear air shocks set @ 30 lbs. unloaded)
LK
Attached Thumbnails need pics of trucks with 2"/4" drop-lkc-1.jpg
Old Sep 9, 2004 | 07:13 PM
TWANKYDEUCE's Avatar
the suspension will be tighter and the truck will have a lower center of gravity so it will handle better...it wont ride like it does now, a little rougher. I have the 2" springs and the 4" shckles and hangers. It doesnt matter if you get spindles or whatever. heres a pic of my truck with a 2/4 but I have rims on it
Old Sep 9, 2004 | 08:15 PM
TwoFast's Avatar
NICE LOOKING TRUCKS SO FAR....... ANYONE ELSE?
Old Sep 9, 2004 | 09:13 PM
slowprocess's Avatar
3/4 drop here
Old Sep 9, 2004 | 09:15 PM
Side view at our race spot
Old Sep 9, 2004 | 10:49 PM
Nick99Chevy's Avatar
If you want it to ride good, get the DJM kit with LCA's in the front.
Old Sep 10, 2004 | 08:02 AM
2/4 - stock wheels
rides good
corners good
I used stock front shocks and IAS on the rear
http://www.cardomain.com/memberpage/528800
Old Sep 10, 2004 | 11:58 AM
12sec.5.3's Avatar
LK
Lets hear more about the c-notch. Is it bolt-on, how hard was the install, $$$? Thanks.
Old Sep 10, 2004 | 03:30 PM
I heard that the c-notch is required for something lower then a 3/5 or if you want to install air shocks on a 3/5 you should do the c-notch or esle your differential will hammer the chassis making some dents on your bed! like my cuzin did to this silverado the c-notch is when you cut a C in the chassis to make clearance for the differantial to go in the chassis and not hammer it/....im i right guys??
