Molding Removal
Old Mar 16, 2007 | 04:17 AM
cpelton's Avatar
Default Molding Removal
I have an 03 arrival blue silverado, wondering if there might be a mark left behind if I remove the molding and 4x4 decals now from the paint fading? Has anyone else removed the molding off an older truck?
cheers
Old Mar 16, 2007 | 09:04 AM
RoosterMcCandles's Avatar
Depends on how the paint has been kept up. If it is been taken care of and waxed regularly you will be ok. If not, it might leave a little behind. Being that new, you should be ok for the most part. I had a 92 that I removed the molding off a few years ago and you could BARELY see where it was if you knew where to look and looked at it right...
Old Mar 16, 2007 | 09:18 AM
beastmode's Avatar
Import Moderator
i removed the moldings off my chevy and it was repainted (cause of a wreck) w/o takin the moldings off which they frequently do, it looked TERRIBLE. as long as your truck was never touched up anywhere liek a bedside or something it should be ok, just be sure to polish then wax several times, it will leave a mark before you do all this but after the polish/wax you should be fine
Old Mar 16, 2007 | 11:21 AM
fake_usa's Avatar
hit it with a little Maguire's scratch X after you peal the **** off and it will blend in any deferences
Old Mar 16, 2007 | 11:42 AM
cpelton's Avatar
sounds good molding = gone next sunny day
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
