Lowering the truck
Old Oct 28, 2004 | 08:40 AM
12sec.5.3's Avatar
Default Lowering the truck
How hard is it to replace the stock hanger with the 2" lowering hanger? Also, can I just buy the hanger without the shackles since I have them already? Thanks!
Old Oct 28, 2004 | 09:58 AM
BigKID's Avatar
Yes, you can buy just the hangers. With the right tools, good drill bit and an air chisle, they are not that hard to change out. Getting the stock rivits out is the most difficult part.
Old Oct 28, 2004 | 11:03 AM
12sec.5.3's Avatar
I've heard you have to drop the gas tank. Do you?
BigKID- I see you have a new best. Congrats! Seems you got the bugs out, what does it run on motor?
Old Oct 28, 2004 | 11:25 AM
Alwhite00's Avatar
I just loosened mine up and pushed it over a little to get at the bolts. Take a cutoff whel and put a slice through the rivit heads and the air chissel will take them right off.
LK
Old Oct 28, 2004 | 01:01 PM
leochevy2001's Avatar
LK
What he said.
Old Oct 28, 2004 | 01:20 PM
BigKID's Avatar
Unfortunately I could only muster a 13.80@97 on motor.
Old Oct 29, 2004 | 10:51 AM
ChevyTrukRacer99's Avatar
I just finished my lowering kit install last week. I ground off all the rivits on the hangers except one on each side i couldn't get to with the grinder, for those i used an air chisel. It's not too hard with the right tools. Like AllWhite said, just loosen the tank up and slide it over a little bit. I did the gas tank side first, cause it's the harder side, so when you get to the other side it seems really easy.
Old Oct 30, 2004 | 09:59 AM
GREGGO's Avatar
Blow torch and be carful!!!. Well, that's how mine were done, but I recommend they way stated above. You don't have to move the gas tank.
Noah Burns
Oct 5, 2015 06:46 AM
wrb002
Aug 31, 2015 12:00 PM
92SS Wagon
14
Aug 4, 2015 06:42 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
