Lowering shackles
Old May 5, 2003 | 03:56 PM
Default Lowering shackles
How do you take the bolts out of the rear spring hanger to install the lowering shackle?This is for a Silverado
Old May 5, 2003 | 04:15 PM
BigKID's Avatar
Default Re: Lowering shackles
Is it a stepside or fleet side? I had not problems with mine but some with stepsides have had to loosen the gas tank to get clearance to pull the drivers' side out.
Old May 5, 2003 | 05:55 PM
sleepersilverado's Avatar
you need to put the frame on jack stands. then take the bottom bolts out of the shackles. now jack the axle up and the spring eyes and the shackle will touch the bottom of the bed's floor. then you will be able to slide the bolt out between the bed floor and the frame rail.then reverse the process to install the new ones.
Ryan
Old May 5, 2003 | 08:20 PM
GREGGO's Avatar
Pretty much do what sleeper said, but on a stepside, you will have to take the last 2 bolts on the bed out and raise the bed slightly. It really isn't as bad as it sounds. Takes about 3 minutes to do each side and it won't mess up the bed alignment.
Old May 5, 2003 | 09:29 PM
Thanks for the help,guys
hodge9386
Oct 25, 2015 01:26 PM
Miguel199
Oct 16, 2015 08:04 PM
BCraven1018
Oct 1, 2015 08:22 PM
X_Racing1
Sep 30, 2015 01:59 AM
vmaxpro
Sep 28, 2015 11:10 AM
