Interior paint?
Old Jan 6, 2009 | 06:12 PM
KySilverado's Avatar
Default Interior paint?
Anybody know where to pick up color matched interior paint? Dark grey.
Old Jan 6, 2009 | 06:19 PM
BLKZ71's Avatar
I get mine from a detail house down the road
Old Jan 6, 2009 | 06:26 PM
Mangled03gmc's Avatar
Baltimore Whore
I wish I could find some, cause the **** they sell at the parts store doesn't match.. Char grey correct Rodge??
Old Jan 6, 2009 | 06:41 PM
Must be nice to be in a large town.
yes, I think.
Old Jan 6, 2009 | 07:04 PM
iamkeniff's Avatar
yeah, i'd like to do charcoal gray and the lower half black with black carpet ....hum how would you go about painting the door panels and lower dash pieces?
Old Jan 6, 2009 | 07:06 PM
Clean them and spray it. Alcohol I'd say.
Old Jan 6, 2009 | 07:10 PM
NyteSnyper's Avatar
If you have a body shop nearby that mixes their own paint, you may check to see if they may be able to mix interior paint. When i was working in the paint shop I mixed my own interior paint (was just a basecoat, no clear) by the code in the glove box and painted it myself. Matched pretty good, had it in the truck for 2 years now, no problems.
Old Jan 6, 2009 | 07:38 PM
02gmcbandit's Avatar
used to work at a body shop, take your truck there and they can color match it. depending on what kind of finish you want depends on what steps you do. if you just want color and still the factory texture, wipe everything down with mineral spirits, scuff with 600 gritt paper, wipe again with mineral spirits, spray, let sit in a moisture free area, temp should be atleast 68 degrees for best results,. up to you far as gloss, if your want a smooth finish, wipe with mineral spirits, scuff with 320-400 gritt, use a high-build primer, spray a medium coat, use 400 gritt to sand smooth, wipe down, spray again with another medium coat, sand until smooth, then go over with 600-800 gritt, wiper with mineral spirits, then spray base,then clear, and if the clear orange peals, i highly recommend wet sanding with 800, then 1200, then buffing with mothers wax.
Old Jan 6, 2009 | 07:51 PM
I've been looking for a center console for months. Seems charcoal grey is the color of choice. They go for about double of other colors. Figured I'd buy a a different color one and paint it.
Old Jan 6, 2009 | 11:35 PM
Frito Bandito's Avatar
SEM makes interior paints. Check their website, I don't know the names of the stuff you will need.
denalircsb
Dec 21, 2020 09:04 AM
cheyenne383
Nov 13, 2015 09:24 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 3, 2015 11:03 PM
the owl
Sep 4, 2015 04:09 PM
