important suspension question?
Old Nov 16, 2003 | 05:56 PM
Crazy03's Avatar
Default important suspension question?
I want to get the hotchkis suspension for my 2003 gmc sierra. (springs and leaf springs for the back) After I do this, a 2-4 drop and say I want it a little lower in the back can I put a shackle kit on the back along with the leaf springs to go a little lower. Thanks
Old Nov 17, 2003 | 04:13 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
If the shackle kit lowers it more than another 2" (6" rear drop) in the back you will have to get the frame c-notched.
I know a guy who lowered his truck 3/5(not Hotchkis), and he says the axle hits the frame when he goes over bumps.
I think his was DJM so that suspension is pretty squishy. I don't know if you could get away with that with the Hotchkis though since it's a pretty stiff ride.
Old Nov 17, 2003 | 10:10 AM
BigKID's Avatar
You would need a c-notch even with the hotchkis springs. I only have about 1.5" of travel to the bumpstops now. But with a c-notch, I seen no problem with adding a 2" schackle to a Hotchkis leaf.
Old Nov 17, 2003 | 12:08 PM
JSmith's Avatar
In addition to what the other guys said I assume that you plan on lowering the front more at the same time if you use a shackle in conjunction with the Hotchkis drop. Otherwise the rear of your truck is going to sit ALOT lower than the front.
Old Nov 17, 2003 | 03:27 PM
Crazy03's Avatar
I ask the question because I am going to do the 2/4 drop from Hotchkis but I was thinking later if I wanted to drop it more, then I wanted to make sure I could do it with a shackle kit. Thanks for the replies
Corvette454l88
Sep 1, 2016 01:24 AM
black03rcsb
Sep 1, 2015 10:17 AM
USMCvet0311
Aug 1, 2015 07:45 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
