How to prep TPO for paint?????
Old May 3, 2011 | 09:56 PM
moregrip's Avatar
what a rush!
Talking How to prep TPO for paint?????
Need help.....want to know how to prep a TPO (Thermoplastic polyolefin) bumper for maximum adhesion?
1. wash item with a mild detergent
2. wet sand to my desired smoothness
3. spot putty a few gouges/fill, sand, smooth
4. wash item with a mild detergent
5. wash item with a wax and grease remover
6. apply Adhesion Promoter
7. apply primer
8. fix defects missed earlier that now show with a primer coat/this step would include another washing; wet sand to scuff the primer coat
9. apply color
10. apply clear
Old May 3, 2011 | 10:10 PM
Mangled03gmc's Avatar
Baltimore Whore
11 wet sand again if needed
12 buff/finish for the final time, wax.
Seems you gots a pretty good idea of what to do. Prep is key to painted, runs in paint and clear, can be dealt with after.. I would also add some type or get a paint made for bumpers( as it will have a flex additive, that will keep from flaking or cracking if flexed). You can X the first step, just start sanding.. Wet sanding will take longer then dry sanding, you do not want the surface totally smooth. It should be a little bit ruff, so the promoter has something to bite into.. I am prob leaving something out, but you seem to have it..
Old May 4, 2011 | 04:03 PM
WorkTruc's Avatar
When washing before and after sanding use scalding hot water to wash and rinse as it will help release oils from mold that were used as a release agent.
Old May 4, 2011 | 04:07 PM
Steve-O-08's Avatar
Nice tips. Should be re-painting my grille and lower valance this weekend.
Old May 4, 2011 | 05:38 PM
moregrip's Avatar
what a rush!
thanks for the tips! I still don't know if I'm brave enough to give this a go....but....I may just have to try it out!
If you have some more info please post it up!
Old May 4, 2011 | 05:44 PM
Baltimore Whore
Just go with it.. Only one way to find out. worst case is you have to get it done again.. No worries
Old May 8, 2011 | 02:52 PM
moregrip's Avatar
what a rush!
well with having access to the paint booth on base maybe I should give it a try???
Old May 8, 2011 | 06:17 PM
Goose33's Avatar
I have adhesion promoter that says clear primer
Do u still need to primer I would think you would?
SS94S10
Jan 3, 2019 01:57 PM
cheyenne383
Nov 13, 2015 09:24 AM
turbo6c3
Oct 5, 2015 06:11 PM
gmcyukon
Oct 3, 2015 11:03 PM
the owl
Sep 4, 2015 04:09 PM
