how to fix crack in bed?
i got a 01 stepside and on the very bottom of the bed it has a crack like 6 inches . i seen some one on here saying they used liquidnail to seal it. im just dont want it to crack all the way.i know it doesnt fix but just need to hold 4 a while, so if any u guys used anything let me know thanks
yeah when my truck was a stepside i cracked one, bought a replacement box side painted it, installed it bla bla bla, expensive, 6 months later re-broke it, Began searching for a fleet thats the best fix for a stepside, they look cool but they are weak as hell.
What he said, or drill a hole slightly wider than the crack to stop it from spreading then use whatever you want to to seal or cover it up. But the drilled hole at the end or ends should stop it from spreading
plastic welding 101 haha
first drill a hole at the end of the crack to stop it from continuing.
next on the back side melt in some type of wire mesh(stronger than window screen) make sure you melt it down into the bed side so it can barely be seen. then on the outside of the panel grind the crack into a V shape so you can melt some plastic in there. after melting plastic into the V groove sand and wipe some mud on her. then paint.
lukn4trbl355
Oct 21, 2015 11:19 PM
jscherbs
Sep 30, 2015 07:54 AM
