how to fix crack in bed?
Old Aug 29, 2009 | 01:31 PM
RickLowpez's Avatar
Default how to fix crack in bed?
i got a 01 stepside and on the very bottom of the bed it has a crack like 6 inches . i seen some one on here saying they used liquidnail to seal it. im just dont want it to crack all the way.i know it doesnt fix but just need to hold 4 a while, so if any u guys used anything let me know thanks
Old Aug 29, 2009 | 02:11 PM
sierraSS's Avatar
new bedside?
Old Aug 29, 2009 | 02:21 PM
RickLowpez's Avatar
whats a bed side costing to repair?
Old Aug 29, 2009 | 03:25 PM
02BlueStepside's Avatar
Have seen the bedsides fixed, but they cracked again. Best bet is a new bedside. Want to say from gm they are in the neighborhood of $700
Old Aug 29, 2009 | 04:26 PM
03lowriderss's Avatar
yeah when my truck was a stepside i cracked one, bought a replacement box side painted it, installed it bla bla bla, expensive, 6 months later re-broke it, Began searching for a fleet thats the best fix for a stepside, they look cool but they are weak as hell.
Old Aug 29, 2009 | 04:38 PM
TXsilverado's Avatar
if its just a crack and theres no misssing pieces they can plastiweld it back together. like welding metal, but with plastic.
Old Aug 29, 2009 | 05:25 PM
Wonderer876's Avatar
What he said, or drill a hole slightly wider than the crack to stop it from spreading then use whatever you want to to seal or cover it up. But the drilled hole at the end or ends should stop it from spreading
Old Sep 4, 2009 | 07:09 PM
bulldogSS's Avatar
plastic welding 101 haha
first drill a hole at the end of the crack to stop it from continuing.
next on the back side melt in some type of wire mesh(stronger than window screen) make sure you melt it down into the bed side so it can barely be seen. then on the outside of the panel grind the crack into a V shape so you can melt some plastic in there. after melting plastic into the V groove sand and wipe some mud on her. then paint.
lukn4trbl355
Oct 21, 2015 11:19 PM
jscherbs
Sep 30, 2015 07:54 AM
tim wellington
Sep 29, 2015 10:17 PM
Slammed silverado
Sep 28, 2015 06:14 PM
trevorh1
Sep 27, 2015 08:47 PM
