How do you... candy tailights?
Old Aug 23, 2009 | 12:54 AM
DBYRD's Avatar
Default How do you... candy tailights?
I have a set of 99 tails that i have laying around and i have seen some online before "candied" and u dont even see the yellow on them but everything else looks great. does anyone know hows this is done since the yellow appears to be part of the diffuser/lens??? i have 03 tails now on my truck but wouldnt mind having this set done up for a diff look...
Old Aug 23, 2009 | 10:24 AM
chevrolet all the way's Avatar
some people get a cheap set of euro tails and get them candied and it looks great. thats my plan but i dropped one of them and cracked it
Old Aug 23, 2009 | 04:10 PM
DBYRD's Avatar
ive seen the factory ones done before but idk where to start...
Old Sep 6, 2009 | 01:27 AM
schothbrite them with red
mix clearcoat and add what ever candy paint in with it and re clear them
Old Sep 6, 2009 | 11:05 PM
DBYRD's Avatar
still confused as to how the yellow is removed unless its not and the paint just covers it so well that it looks red. the ones ive seen looked like the yellow was removed tho...
Old Sep 7, 2009 | 12:09 AM
Y2KSierra's Avatar
The yellow is painted over. First, you'd scuff/sand the taillight and tape off any parts you don't want painted. I did a set a long time ago that kept the reverse light and I've done sets where everything is red. I always had really good luck with Testors Candy Apple Red in a spray can. After it's done, let it fully cure and then sand it with 800-1500 sandpaper to level up the paint and to make sure the color is nice and even. If you are happy with how it looks, then it's time to spray clear coat. I usually used auto grade clear and a spray gun for the last step to prevent fading and to give a factory like finish.
Here are some examples of lights I've done in the past using the above method.
Hope this helps..
Old Sep 7, 2009 | 11:28 PM
DBYRD's Avatar
this helps a ton thank u! i just wanted to make sure i wasnt missing anything.
ACDenali
May 3, 2005 07:06 AM
creederado
Nov 19, 2004 09:03 PM
creederado
Aug 1, 2004 01:46 PM
Barely Boosted
Apr 29, 2004 09:30 PM
ACDenali
Mar 10, 2004 03:29 PM
