how to brush raised ribs?
Old Feb 26, 2009 | 08:12 AM
BigCountryx's Avatar
Default how to brush raised ribs?
Looking to get a cast aluminum piece powdercoated and it is flat with raised ribs on it. I want the the piece coated black with the ribs being a machined/brushed look. Should I just have it powdercoated then block sand the coating off of the high spots or should they be taped off prior to coating?
Old Feb 26, 2009 | 10:06 AM
Just got off the phone a local powdercoater, he said he'd PC the whole part and that I should block sand the raised section to remove the coating. I was worried that it would peel at the edge of where I sand, but he said it wouldn't..... Thoughts?
Old Feb 26, 2009 | 10:18 AM
MikeZQ8SS's Avatar
I'm not sure exactly. Dunno why it wouldn't work, but I've wondered the same thing for a while. I've thought about doing that with painted stuff, not powdercoated though. Someone who knows their stuff will be along soon enough...
Old Feb 26, 2009 | 05:12 PM
2BFAST's Avatar
I did it on a part on my buddies 00' Stang. I actually used my Dremel with a small wire wheel on low speed. I guess it all depends on what the part looks like.....pics??
Old Feb 26, 2009 | 07:41 PM
regency's Avatar
it will work like he told you. ive done many many parts like that. even with paint it will work great, as long as your paint is done right and not some cheap crap
Old Feb 26, 2009 | 11:57 PM
cheyenne383's Avatar
TOWN CRIER
Powdercoating isn't going to flake off like cheap/poorly prepped paint will. If it does, it wasn't applied right. As long as the coating is quality work, sanding it off will work just fine.
Old Feb 27, 2009 | 12:23 AM
Mangled03gmc's Avatar
Baltimore Whore
Agreed
I would however block it nice and smooth first, so all you will need to do after is work it a lil bit....
Old Feb 27, 2009 | 10:27 AM
thanks for the tips guys... got a plan now
wretched73
Oct 28, 2015 09:21 PM
LT-1 SS
Sep 26, 2015 05:19 AM
murderedSS
Sep 22, 2015 03:53 AM
00loudchevy
Sep 11, 2015 07:55 AM
