High grip tires
Old Jan 19, 2005 | 02:35 PM
moregrip's Avatar
what a rush!
Originally Posted by smooth sierra
don't confuse tread wear with traction traction would be a A or an AA being the best. I personally recommend nitto extreme force 404. they have a 420 tread wear rating with traction A temperature A. they ride SMOOTH and quite and grip the road excellent in dry and wet conditions. a 300 treadwear tire might last 25-30k where as a 420 treadwear might see as much as 45k miles if treated right. I guess it all depends on what your expectations are and how often you want to buy tires.
I did mis-speak, however, I am not confused, I usually double check before I post so I don't misrepresent facts, thanks.
200 and 300 are the correct #'s for the treadwear
Old Jan 19, 2005 | 03:41 PM
BigKID's Avatar
When I had my 18's I had both a Yokohama AVS and Nitto 404 in 285/50/18. I will take the nittos over the yokos anyday. Rode smoother, less noisy, better dry traction(about equal wet traction/hydroplane resistance) and were 80 bucks less a tire. Although the Yoko were a very good looking agressive tire, the just wern't the 'premier' sport truck tire the are advertised to be. Now that the 18s are gone, I will be putting a set of Toyo Proxies in a 275/60/16 on my stock aluminum rims on friday. I will let yall know how they do. Anything has to be better than these 235 wranglers I currently have on there though.
Old Jan 19, 2005 | 04:47 PM
2000 SILVERADO's Avatar
What should I get for the front? It's going to look like crap having stock tires in the front, and if I do change them too, should I get some thiner treads for the front?
GXPJAY
Feb 13, 2022 08:15 AM
Zizzle
Oct 19, 2017 08:44 PM
bgray
Jul 23, 2015 10:56 AM
Ammadien
Jul 22, 2015 08:50 PM
