High grip tires
Old Jan 16, 2005 | 12:43 PM
2000 SILVERADO's Avatar
Default High grip tires
What are some good tires that grip up well? Thanks.
Old Jan 16, 2005 | 01:17 PM
moregrip's Avatar
what a rush!
BFG Gforce KD or KDW's. 200 and 300 traction rating.
Old Jan 16, 2005 | 01:30 PM
How much are they and where can I get them?
Old Jan 17, 2005 | 08:14 AM
bud8fan's Avatar
www.tirerack.com has them...discount tire co...prolly your local hi volume tire dealer..even walmart can order them for you from their tire catalog.
Old Jan 17, 2005 | 08:58 PM
goshawk23's Avatar
Truck addict
i think wally world is probably the cheapest place to get them
Old Jan 17, 2005 | 09:08 PM
slowprocess's Avatar
Yeah, didn't me, you, and Daniel have this convo one night?
Old Jan 17, 2005 | 09:16 PM
goshawk23's Avatar
Truck addict
yes sir
Old Jan 18, 2005 | 10:03 PM
What would be a good size for the rear?
Old Jan 19, 2005 | 06:52 AM
smooth sierra's Avatar
don't confuse tread wear with traction traction would be a A or an AA being the best. I personally recommend nitto extreme force 404. they have a 420 tread wear rating with traction A temperature A. they ride SMOOTH and quite and grip the road excellent in dry and wet conditions. a 300 treadwear tire might last 25-30k where as a 420 treadwear might see as much as 45k miles if treated right. I guess it all depends on what your expectations are and how often you want to buy tires.
Old Jan 19, 2005 | 02:32 PM
blue 01's Avatar
I have had my Toyo proxes ST for 30,000 miles and love them. The big plus is the ( Rim protector to guard against wheel and sidewall damage) it works. Some of the dam drive-thru window are tight to get through. The tread wear is amazing.
Here are the specs
- Mud and snow (M&S) rated for all-season performance
- High angle tread groove to resist aquaplaning
- Low angle tread grooves excellent for wet handling
- High ply turn-up casing construction for handling and stability
- High bead filler for excellent steering response
- Jointless two-cap ply for high-speed endurance.
- Cap/base compound for high speed durability. The base compound helps the tire run cooler. The cap compound provides high friction and wear resistance.
- Rim protector to guard against wheel and sidewall damage.
- High tensile steel belts for ride comfort and stable ride
- High-modulus bead filler and strong polyester casing assure responsive handling with excellent ride comfort.
- Aggressive tread pattern and sidewall design for sporty appearance.
- Jointless bead wire for uniformity and balance.
- H and V speed-rated (depending on size)
- UTQG Treadwear 420
- UTQG Traction A
- UTQG Temperature A
- M and S Rated
