help! glue still on after pinstiripe(pics)
Old Oct 28, 2006 | 01:04 PM
JJay3's Avatar
Default help! glue still on after pinstiripe(pics)
i removed pinstripe because it started peeling off...
now there is glue
whats the best way to take it off? i tried goo gone, but it takes too long... any faster way?
Old Oct 28, 2006 | 01:40 PM
RERICK's Avatar
You could try some type of clear coat polish. I have had good luck using , Ford clear coat polish . You will probibly end up doing the whole truck once you start ,though .
Ron
Old Oct 28, 2006 | 02:02 PM
Nick™'s Avatar
3M makes an adhesive removing wheel, it fits on your drill, works really well
Old Oct 28, 2006 | 02:03 PM
TXsilverado's Avatar
gasoline worked for me
Old Oct 28, 2006 | 02:07 PM
JJay3's Avatar
i dont want to use clearcoat polish if i have to do the whole truck.
i heard it can mess up the clearcoat? whats the 3m wheel called?
i might try gasoline later.
Old Oct 28, 2006 | 02:15 PM
make sure you wash and wax the area after you gas it. it strips your wax
Old Oct 28, 2006 | 02:24 PM
its called pinstripe removal wheel. it only messes with your paint if you spin in harder than 2000rpm....my drill only goes to 800. i used it and didnt mess anything up
Old Oct 28, 2006 | 03:03 PM
nice_n_lo_silverado's Avatar
I have a 3M adhesive romover in a can...worked very well on the badges and I am sure it will work on this.
Old Oct 28, 2006 | 03:16 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Goo gone and a hair dryer or heat shrink gun set on low. Scrape with plastic putty knife or scrub with a towel.
Old Oct 28, 2006 | 03:29 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
WD40 will remove it and not hurt the paint.
SloSVO
Nov 22, 2020 07:34 PM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
GMCtrk
Oct 5, 2015 11:18 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
