help with 10inch rim
Old Aug 12, 2005 | 02:47 PM
trust me guys, if it turns out like i want it to, i will put up some pics because i dont know if i have ever seen an 18x10 on the front of a 2wd 1/2 ton at stock height. keeping my fingers crossed. i've seen 20x10's but never a 10in wide for a rim under that size and with the kind of offset i have. discount said theyd work it out if there was a problem so we'll see
Old Aug 12, 2005 | 10:21 PM
SnakeOiler's Avatar
If you want I can put my 20x10 with 7" backspace(38mm offset), 295/45 tire, on the front and take a picture for you.
Old Aug 15, 2005 | 03:11 PM
sorry it took so long for a reply, snake that would be awesome if you could do that because if these wheels dont fit then i will be looking for a different set because ill have to send these back and find a different set. any help is appreciated. thanks
Bryan
Old Aug 16, 2005 | 03:35 PM
SnakeOiler's Avatar
OK, this is a pic of my 20x10, 7"backspace mounted with 295/45 BFG KDW. This is basically a stock diameter tire - only .4" more than the stock Generals. My truck sits at stock height, as well - not lowered, yet.
Lock to lock, everything clears fine, BUT the anti-sway bar only clears by about 3/16" - if that much. I cannot say if it would clear under stress.
Old Aug 17, 2005 | 02:27 PM
thanks snake, you are the man. i really appreciated you helping me out. 2 more days till i found out if my wheels will fit. wish me luck
wretched73
Oct 28, 2015 09:21 PM
whitelazer
Sep 22, 2015 09:38 PM
kmcn47
Sep 17, 2015 01:12 AM
askkmb
Sep 7, 2015 10:58 PM
Sdailey
Sep 6, 2015 10:26 PM
