help with 10inch rim
Old Aug 9, 2005 | 02:50 PM
Default help with 10inch rim
hey guys, i could only get my 10inch wide rim in a zero mm offset. can anyone tell me how far they will probably stick out from under the truck. according to the guy at discount tire because it sticks out i had to run a smaller tire. i wanted to run 285's but he told me i could only run 275's without serious rubbing. he told me i would have to trim plastic even with the 275s. any opinions???????
Old Aug 9, 2005 | 05:47 PM
EDawg's Avatar
Old Aug 9, 2005 | 05:53 PM
ok, the rims have 0 offset which means i have even backspacing(5 front/5rear). i wanted to run285/50/18's but the guy at discount told me that it would rub too bad and i would have to run275/60/18.
Old Aug 9, 2005 | 07:15 PM
EDawg's Avatar
the 285-50-18's will fit fine. it is 29.3" tall and has a section with of 11.7
the 275-60-18 is allmost 2 inchs taller and has a section with of 10.9
i think that guy is full of if you ask me. i sell wheels and tires. and don't see any problems with it fitting
Old Aug 9, 2005 | 09:13 PM
SnakeOiler's Avatar
Actually, the 0mm offset gives you a 5.5" backspace. Neither tire is going to clear the fender lip - the wheel just doesn't have enough backspace. Although, you will have more clearance, before that fender lip reaches the tire, with the 285
Old Aug 10, 2005 | 03:29 PM
i want the rims to stick out a little. its just that the guy told me that the tire would rub the inner fenderwell too badly. truck is stock height also
Old Aug 10, 2005 | 08:03 PM
SnakeOiler's Avatar
You're not gonna come close to the inner fender well. The outer is a different story.
Old Aug 11, 2005 | 02:41 PM
went to discount to talk to the guy some more about the wheels. he showed me a 20in wheel with the same tire size and 10mm offset and told me it would fit with little trimming so i would have to do just a little more and it will be the outer part of the fenderwell plastic that i will be having to trim. he said we would test fit them when they came in and if it wasnt doable then we'd work something out. i guess thats all i really wanted to know, that i wasnt screwed if they didnt fit. thanks for all your help guys
Old Aug 11, 2005 | 09:56 PM
SnakeOiler's Avatar
You're gonna put a 10" wide wheel on the front? I wanted to do that, too, but I could not come up with a backspacing that I felt comfortable with where I wouldn't have interference problems.
So I went with 8.5" front and 10" rear
Old Aug 11, 2005 | 10:19 PM
HioSSilver's Avatar
33x12.50 fits hd trucks maybe they would fit the 1/2 ton too.
