Headlight Mod for $1
#262
Plan to do this (these) Mod(s) - all pictures are so old that they aren't available anymore...can anyone post pics of what this looks like at the relay under the hood? If I understand correctly, you just add the diode between the relays (at the specific pin) along-side the pin? Any help is appreciated. Thanks
#265
Does anybody have a preference on which one of these diodes to use? One is just a 12 volt and the other is just the part # listed on the first page. I run HID lows if that matters. Thanks
#266
just read a couple pages back that the 'zener' type diode won't work properly...
EDIT: I went ahead and tried the other diode (IN4004) and it works fine. I couldn't get the diode inside the wiring pins under the dash without bending so I used the relay method.
#267
Mine were the same way. Its your ambient light sensor. I pulled the sensor and clipped the wires, then added an LED between the wires. You can either buy a new sensor or add some resistance between the wires and it will force your DRLs to be on all the time. Hope this helps.
#268
What year truck do you have? Sorry if its in your sig or whatever I'm on the mobile site
GM1697
Sep 9, 2015 01:52 PM
