First Time I didn't Lower Something...
Old May 28, 2013 | 10:09 AM
bpope's Avatar
Default First Time I didn't Lower Something...
Hello all, after owning many fullsize GM trucks, I have always lowered them. This time I was looking to do a little something different. I got my rough country 2" level kit installed over the weekend. First side I loosened everything without completely seperarting the upper ball joint. Second side I just removed the lower strut bolts and pried down on the control arm and slid the spacer in. Pretty simple intstall. Truck is a 2011, LTZ with black interior. Next step is to put on some 305/50r20 Terra Grapplers. Thanks for the help on this site! On to the pics.
Old May 28, 2013 | 09:34 PM
Truck looks good. Tires should top it off. Think you will like the 305 50 20 Nitto TGs with the 2" level and OEM 20s.
Old May 28, 2013 | 09:47 PM
cammed00's Avatar
I agree with him ^...the tires will definataly set it off
Old May 29, 2013 | 08:01 AM
bpope's Avatar
Thanks guys. Sebring - is that what tire you are running on yours? Did you notice any decrease in mileage and how does it drive with that wide of a tire. I do sometimes go back and forth with going to a 275/60. Thanks for the input!
Old May 29, 2013 | 07:09 PM
Yes I have 305 50 20 Nitto TGs. I'm not a good gauge on mileage because I average about 12 mpg with my 6.2L. I live 2 miles from work and sit in stop and go traffic most everywhere I go. On road trips I've gotten 4 to 5 mpg more. The tires are definitely heavier than the 275 55 20 OEM Goodyears, but they ride and drive better and aren't any noisier. I went with the 305 50s to keep the 32" tire diameter. Plus I personally like a wider/shorter look instead of skinny/taller. You might look at 285 55s or 285 50s if you want something between a 275 and 305. I've got another set of rims with a negative offset that I'm about to buy tires for and think I'm going to buy 285 50s.
Old May 29, 2013 | 10:27 PM
bpope's Avatar
Thanks for the response. If they drive just as good as the 275/55, then I am good with a slight drop in mileage. I checked on 285/55r20 in both toyo and nitto and I heard they are a good bit heavier than than even a 305/50 since they are 10 ply. 285/50 might be a good option as you mention. I will have to see if I can find some pics. I definitely dont want to go with a 33" tall tire like the 305/55s.
Oobray
Jun 13, 2022 03:38 AM
chevyl33
Aug 24, 2015 08:21 AM
mrhino
Aug 7, 2015 10:01 AM
92SS Wagon
14
Aug 4, 2015 06:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
