Finally
Old Nov 2, 2011 | 07:23 PM
  #21
bmd_CL's Avatar
its on the, i guess highest ride, setting and it lowered it 2 inches... If i move it to the next one, moving the leaf spring higher, would lower the truck....
Old Nov 2, 2011 | 07:29 PM
  #22
ak2007r6's Avatar
Truck looks good.
Oh and if you want to multi quote select each post with the far right button then click post reply. Wasn't sure if you knew how or not.
Old Nov 2, 2011 | 07:37 PM
  #23
dlt76028's Avatar
yes moving the leafs higher will lower your truck. put them on the highest hole to get the most drop.
Old Nov 2, 2011 | 07:39 PM
  #24
bmd_CL's Avatar
Thanks for the compliment. and yea i thought thats what you had to do but wasnt positive lol
Old Nov 2, 2011 | 07:40 PM
  #25
bmd_CL's Avatar
yes, and the lowest hole on the shackles lowered it 2 inches, so in theory... the next hole should lower it another inch
Old Nov 2, 2011 | 08:06 PM
  #26
black00chev's Avatar
Slowest turbo build ever!
im pretty sure my buddies regency ecsb sierra has 3" shackles from Regency...
Next time you get a chance look at where the rear bumpstops are mounted... If they are not mounted DIRECTLY to the frame you can remove the bracket that they are on and they will mount on the frame just fine. I have my truck done this way. Give you another 2" or so of clearance.
Old Nov 2, 2011 | 08:33 PM
  #27
dlt76028's Avatar
ok guys link me to these 3" shackles? and fyi lowering shackles vary in length and depending on the truck can lower 1"-2", then you have to take in account tire size change, front drop, gas, ect... to the op, your truck looks dropped 3" in the rear to me.
Old Nov 2, 2011 | 10:18 PM
  #28
gs7793's Avatar
no
to get 3" out of a shackle you have to get a special shackle (3/4 ton) and cut out the bed above the shackle to make it fit correctly, i know a guy who has it done
Old Nov 2, 2011 | 10:20 PM
  #29
gs7793's Avatar
btw, my shackle has 5 adjustable holes on it....doesnt mean its a 5" drop shackle lol
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
