Few 2/4 drop questions....
Old Feb 24, 2007 | 10:44 AM
10RamSport's Avatar
Formerly 08_gmc_slt-08/20/2010
Default Few 2/4 drop questions....
1. Will stock shocks work?
2. Will 285/50/20's cause any rubbing issues?
3. Do I need pinion shims?
Thanks for the help!
Old Feb 24, 2007 | 10:51 AM
NegraRCSB2X4auto's Avatar
yes they will rub up front i went 45 and they don't rub my friend has 50s and the outsides rub when they hit a dip.
Old Feb 24, 2007 | 01:43 PM
bgray's Avatar
TOTM: June 2007
no on pion shims..yes on new carrier bearing bracket..and use your stock shocks
Old Feb 24, 2007 | 03:12 PM
jhe2003's Avatar
Don't mean to hijack, but where can I get the carrier bearing bracket? thanks
Old Feb 25, 2007 | 09:00 AM
1badsilver's Avatar
You shouldn't need new shocks but it wouldn't be a waste of time or money.
285/50s should work with very, very minor rubbing
A carrier bearing is necessary? I've been running my 2/4 drop for 2 years, never a problem. Should I invest in one though?
Old Feb 25, 2007 | 12:00 PM
10RamSport's Avatar
Thanks for the input guys!
Anyone else have any thoughts? Its the rubbing issue that is bothering me....
Old Feb 25, 2007 | 07:35 PM
Siiverado44's Avatar
They will rub. Nothing wrong with 275/45/20 though.
Do not use the stock shocks if you go with a leaf/spring kit. They are not designed to handle it, and you will ruin your bumpstop. I can't say about shackles and hangers though.
Old Feb 26, 2007 | 08:05 AM
10RamSport's Avatar
The wheels also have a 20mm offset if that helps. I am just worried about spending the $$ on an install and then they rub.
USMCvet0311
Jan 16, 2016 06:04 PM
smok'nZ
Oct 6, 2015 01:14 PM
X_Racing1
Sep 30, 2015 01:59 AM
twake_410
Sep 25, 2015 10:09 PM
