Escalade door handles
OK since i have searched for part numbers for a dark blue metallic door handle set for my silverado on this board a few times i figured that i would make my own thread since that seems to be the trend to seek for help. if anyone knows the part numbers for escalade door handles in dark blue metallic it would be greatly appreciated. oh and just for the fronts. thanks
-Ryan
-Ryan
If it's the same color as Indigo Blue Metallic, the paint code is 39. You should be able to call your dealer and get a part number(s). If you give them the paint code, you should be able to get the correct part numbers.
Here you go!
Call a local Cadillac dealer around your area and give them the following numbers: 5R238440
Tell them you would like to order the handles off of this Escalade, those 8-digits will come up with the door handle part numbers and all the various accessories for that Escalade.
Yes, this will be a Blue Chip Escalade and the handles will come in that color,
I ordered a set for my truck with those numbers and got the right handles.
Hope this helps you out!
By the way, the front passenger door will come with out a key hole and the driver door will have a key hole.
